指定活动图层。 支持的平台:仅窗口 言论创建新对象时,这些对象将放置在活动图层上。要更改现有对象所在的图层,请使用该对象的属性。Layer 要创建新图层,请使用该方法。Add 要更改图层的可见性或其他属性,请参阅对象。Layer 例子工 务 局: Sub Example_ActiveLayer() ' This example returns the current layer ' and then adds a new layer. ' Finally, it returns the layer to the previous setting. Dim currLayer As AcadLayer Dim newLayer As AcadLayer ' Return the current layer of the active document Set currLayer = ThisDrawing.ActiveLayer MsgBox "The current layer is " & currLayer.name, vbInformation, "ActiveLayer Example" ' Create a Layer and make it the active layer Set newLayer = ThisDrawing.Layers.Add("TestLayer") ThisDrawing.ActiveLayer = newLayer MsgBox "The new layer is " & newLayer.name, vbInformation, "ActiveLayer Example" ' Reset the layer to its previous setting ThisDrawing.ActiveLayer = currLayer MsgBox "The active layer is reset to " & currLayer.name, vbInformation, "ActiveLayer Example" End Sub Visual LISP: (vl-load-com) (defun c:Example_ActiveLayer() ;; This example returns the current layer ;; and then adds a new layer. ;; Finally, it returns the layer to the previous setting. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Return the current layer of the active document (setq currLayer (vla-get-ActiveLayer doc)) (alert (strcat "The current layer is " (vla-get-Name currLayer))) ;; Create a Layer and make it the active layer (setq layers (vla-get-Layers doc)) (setq newLayer (vla-Add layers "TestLayer")) (alert (strcat "The new layer is " (vla-get-Name newLayer))) ;; Restore the previous layer (setq currLayer (vla-get-ActiveLayer doc)) (alert (strcat "The active layer is restored to " (vla-get-Name currLayer))) ) |
GMT+8, 2024-6-10 22:29
