将当前视口缩放到给定的比例因子。 支持的平台:仅窗口 签名工 务 局: object.ZoomScaled Scale, ScaleType
返回值(RetVal)无返回值。 言论此方法适用于当前活动视口(图纸空间视口或模型空间视口)。 例子工 务 局: Sub Example_ZoomAll() ' This example creates several objects in model space and ' then performs a variety of zooms on the drawing. AppActivate ThisDrawing.Application.Caption ' Create a Ray object in model space Dim rayObj As AcadRay Dim basePoint(0 To 2) As Double Dim SecondPoint(0 To 2) As Double basePoint(0) = 3#: basePoint(1) = 3#: basePoint(2) = 0# SecondPoint(0) = 1#: SecondPoint(1) = 3#: SecondPoint(2) = 0# Set rayObj = ThisDrawing.ModelSpace.AddRay(basePoint, SecondPoint) ' Create a polyline object in model space Dim plineObj As AcadLWPolyline Dim points(0 To 5) As Double points(0) = 3: points(1) = 7 points(2) = 9: points(3) = 2 points(4) = 3: points(5) = 5 Set plineObj = ThisDrawing.ModelSpace.AddLightWeightPolyline(points) plineObj.Closed = True ' Create a line object in model space Dim lineObj As AcadLine Dim startPoint(0 To 2) As Double Dim endPoint(0 To 2) As Double startPoint(0) = 0: startPoint(1) = 0: startPoint(2) = 0 endPoint(0) = 2: endPoint(1) = 2: endPoint(2) = 0 Set lineObj = ThisDrawing.ModelSpace.AddLine(startPoint, endPoint) ' Create a circle object in model space Dim circObj As AcadCircle Dim centerPt(0 To 2) As Double Dim radius As Double centerPt(0) = 20: centerPt(1) = 30: centerPt(2) = 0 radius = 3 Set circObj = ThisDrawing.ModelSpace.AddCircle(centerPt, radius) ' Create an ellipse object in model space Dim ellObj As AcadEllipse Dim majAxis(0 To 2) As Double Dim center(0 To 2) As Double Dim radRatio As Double center(0) = 5#: center(1) = 5#: center(2) = 0# majAxis(0) = 10: majAxis(1) = 20#: majAxis(2) = 0# radRatio = 0.3 Set ellObj = ThisDrawing.ModelSpace.AddEllipse(center, majAxis, radRatio) ' ZoomAll MsgBox "Perform a ZoomAll", , "ZoomWindow Example" ZoomAll ' ZoomWindow MsgBox "Perform a ZoomWindow using the following coordinates:" & vbCrLf & _ "1.3, 7.8, 0" & vbCrLf & _ "13.7, -2.6, 0", , "ZoomWindow Example" Dim point1(0 To 2) As Double Dim point2(0 To 2) As Double point1(0) = 1.3: point1(1) = 7.8: point1(2) = 0 point2(0) = 13.7: point2(1) = -2.6: point2(2) = 0 ZoomWindow point1, point2 ' ZoomScaled MsgBox "Perform a ZoomScaled using:" & vbCrLf & _ "Scale Type: acZoomScaledRelative" & vbCrLf & _ "Scale Factor: 2", , "ZoomWindow Example" Dim scalefactor As Double Dim scaletype As Integer scalefactor = 2 scaletype = acZoomScaledRelative ZoomScaled scalefactor, scaletype ' ZoomExtents MsgBox "Perform a ZoomExtents", , "ZoomWindow Example" ZoomExtents ' ZoomPickWindow MsgBox "Perform a ZoomPickWindow", , "ZoomWindow Example" ZoomPickWindow ' ZoomCenter MsgBox "Perform a ZoomCenter using:" & vbCrLf & _ "Center 3, 3, 0" & vbCrLf & _ "Magnification: 10", , "ZoomWindow Example" Dim zcenter(0 To 2) As Double Dim magnification As Double zcenter(0) = 3: zcenter(1) = 3: zcenter(2) = 0 magnification = 10 zoomcenter zcenter, magnification End Sub Visual LISP: (vl-load-com) (defun c:Example_ZoomAll() ;; This example creates several objects in model space and ;; then performs a variety of zooms on the drawing. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) (setq modelSpace (vla-get-ModelSpace doc)) ;; Create a Ray object in model space (setq basePoint (vlax-3d-point 3 3 0) secondPoint (vlax-3d-point 1 3 0)) (setq rayObj (vla-AddRay modelSpace basePoint secondPoint)) ;; Create a polyline object in model space (setq points (vlax-make-safearray vlax-vbDouble '(0 . 5))) (vlax-safearray-fill points '(3 7 9 2 3 5 ) ) (setq plineObj (vla-AddLightWeightPolyline modelSpace points)) (vla-put-Closed plineObj :vlax-true) ;; Create a line object in model space (setq startPoint (vlax-3d-point 0 0 0) endPoint (vlax-3d-point 2 2 0)) (setq lineObj (vla-AddLine modelSpace startPoint endPoint)) ;; Create a circle object in model space (setq centerPt (vlax-3d-point 20 30 0) radius 3) (setq circObj (vla-AddCircle modelSpace centerPt radius)) ;; Create an ellipse object in model space (setq center (vlax-3d-point 5 5 0) majAxis (vlax-3d-point 10 20 0) radRatio 0.3) (setq ellObj (vla-AddEllipse modelSpace center majAxis radRatio)) ;; ZoomAll (alert "Perform a ZoomAll") (vla-ZoomAll acadObj) ;; ZoomWindow (alert (Strcat "Perform a ZoomWindow using the following coordinates:" "\n1.3, 7.8, 0" "\n13.7, -2.6, 0")) (setq point1 (vlax-3d-point 1.3 7.8 0) point2 (vlax-3d-point 13.7 -2.6 0)) (vla-ZoomWindow acadObj point1 point2) ;; ZoomScaled (alert (strcat "Perform a ZoomScaled using:" "\nScale Type: acZoomScaledRelative" "\nScale Factor: 2")) (setq scalefactor 2 scaletype acZoomScaledRelative) (vla-ZoomScaled acadObj scalefactor scaletype) ;; ZoomExtents (alert "Perform a ZoomExtents") (vla-ZoomExtents acadObj) ;; ZoomPickWindow (alert "Perform a ZoomPickWindow") (vla-ZoomPickWindow acadObj) ;; ZoomPrevious (alert "Perform a ZoomPrevious") (vla-ZoomPrevious acadObj) ;; ZoomCenter (alert (strcat "Perform a ZoomCenter using:" "\nCenter 3, 3, 0" "\nMagnification: 10")) (setq zcenter (vlax-3d-point 3 3 0) magnification 10) (vla-ZoomCenter acadObj zcenter magnification) ) |
GMT+8, 2024-6-2 18:19
