从多行文本更新属性,从属性更新多行文本。 支持的平台:仅窗口 返回值(RetVal)无返回值。 言论没有额外的评论。 例子工 务 局: Sub Example_MTextAttribute() ' This example creates an attribute definition in model space. ' It then manipulates its MText properties Dim attributeObj As IAcadAttribute Dim height As Double Dim mode As Long Dim prompt As String Dim insertionPoint(0 To 2) As Double Dim tag As String Dim value As String ' Define the attribute definition height = 1.4 mode = acAttributeModeVerify prompt = "New Prompt" insertionPoint(0) = 5.2: insertionPoint(1) = 5.7: insertionPoint(2) = 0 tag = "NEW_TAG" value = "New Value" ' Create the attribute definition object in model space Set attributeObj = ThisDrawing.ModelSpace.AddAttribute(height, mode, prompt, insertionPoint, tag, value) attributeObj.MTextAttribute = True attributeObj.MTextAttributeContent = "test content" attributeObj.MTextBoundaryWidth = 4.2 attributeObj.UpdateMTextAttribute ZoomAll End Sub Visual LISP: (vl-load-com) (defun c:Example_MTextAttribute() ;; This example creates an attribute definition in model space. ;; It then manipulates its MText properties (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Define the attribute definition (setq insertionPoint (vlax-3d-point 5.2 5.7 0) attHeight 1.4 attMode (+ acAttributeModeVerify acAttributeModeMultipleLine) attPrompt "New Prompt" attTag "NEW_TAG" attValue "New Value") ;; Create the attribute definition object in model space (setq modelSpace (vla-get-ModelSpace doc)) (setq attributeObj (vla-AddAttribute modelSpace attHeight attMode attPrompt insertionPoint attTag attValue)) (vla-put-MTextAttributeContent attributeObj "test content") (vla-put-MTextBoundaryWidth attributeObj 4.2) (vla-UpdateMTextAttribute attributeObj) (vla-ZoomAll acadObj) ) |
GMT+8, 2024-6-10 20:26
