标记操作块的开始。 支持的平台:仅窗口 返回值(RetVal)无返回值。 言论此方法允许 AutoCAD 设置必要的环境,以便将此调用和调用之间完成的操作视为一组操作。EndUndoMark 例子工 务 局: Sub Example_StartUndoMark() ' This example creates a series of lines, each with an undo marker ' defined for it. After lines are created, you can switch to AutoCAD and type ' the Undo command, and only one line at a time will be undone. If StartUndoMark ' call is not made, an undo in AutoCAD will undo all the lines at once. Dim line As AcadLine Dim stPnt(0 To 2) As Double Dim endPnt(0 To 2) As Double stPnt(0) = 1: stPnt(1) = 2: stPnt(2) = 0 endPnt(0) = 2: stPnt(1) = 1: stPnt(2) = 0 ' Create the lines Dim j As Integer For j = 0 To 3 ThisDrawing.StartUndoMark Set line = ThisDrawing.ModelSpace.AddLine(stPnt, endPnt) stPnt(0) = stPnt(0) + 3 endPnt(0) = endPnt(0) + 3 ThisDrawing.EndUndoMark Next ZoomAll End Sub Visual LISP: (vl-load-com) (defun c:Example_StartUndoMark() ;; This example creates a series of lines, each one with an undo marker ;; defined for it. After lines are created you can switch to AutoCAD and type ;; the Undo command, and only one line at a time will be undone. If StartUndoMark ;; call is not made, an undo in AutoCAD will undo all the lines at once. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) (setq modelSpace (vla-get-ModelSpace doc)) (setq stPnt (vlax-3d-point 1 2 0) endPnt (vlax-3d-point 2 1 0)) ;; Create the lines (setq j 0) (while (>= 3 j) (vla-StartUndoMark doc) (setq line (vla-AddLine modelSpace stPnt endPnt)) (vlax-safearray-put-element (vlax-variant-value stPnt) 0 (+ (vlax-safearray-get-element (vlax-variant-value stPnt) 0) 3)) (vlax-safearray-put-element (vlax-variant-value endPnt) 0 (+ (vlax-safearray-get-element (vlax-variant-value endPnt) 0) 3)) (setq j (1+ j)) (vla-EndUndoMark doc) ) (vla-ZoomAll acadObj) ) |
GMT+8, 2024-6-2 19:31
