将视口中的视图设置为 Views 集合对象中的已保存视图。 支持的平台:仅窗口 返回值(RetVal)无返回值。 言论没有额外的评论。 例子工 务 局: Sub Example_SetView() ' This example creates a new view. ' It then changes the active viewport to ' the newly created view. ' Create a new view Dim viewObj As AcadView Set viewObj = ThisDrawing.Views.Add("TESTVIEW") ' Set the view characteristics viewObj.center(0) = 374: viewObj.center(1) = 313 viewObj.Width = 450 viewObj.Height = 354 ' Get the current active viewport Dim viewportObj As AcadViewport Set viewportObj = ThisDrawing.ActiveViewport MsgBox "Change to the saved view.", , "SetView Example" ' Set the view in the viewport viewportObj.SetView viewObj ThisDrawing.ActiveViewport = viewportObj ThisDrawing.Regen True End Sub Visual LISP: (vl-load-com) (defun c:Example_SetView() ;; This example creates a new view. ;; It then changes the active viewport to ;; the newly created view. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Create a new view (setq viewObj (vla-Add (vla-get-Views doc) "TESTVIEW")) ;; Set the view characteristics (setq centerPoint (vlax-make-safearray vlax-vbDouble '(0 . 1))) (vlax-safearray-fill centerPoint '(374 313)) (vla-put-Center viewObj centerPoint) (vla-put-Width viewObj 450) (vla-put-height viewObj 354) ; Get the current active viewport (setq viewportObj (vla-get-ActiveViewport doc)) (alert "Change to the saved view.") ;; Set the view in the viewport (vla-SetView viewportObj viewObj) (vla-put-ActiveViewport doc viewportObj) (vla-Regen doc :vlax-true) ) |
GMT+8, 2024-6-2 22:10
