指定真彩色的 RGB 值。 支持的平台:仅窗口 签名工 务 局: object.SetRGB Red, Green, Blue
返回值(RetVal)无返回值。 言论没有额外的评论。 例子工 务 局: Sub Example_SetRGB() ' This example draws a line and returns the RGB values Dim color As AcadAcCmColor Set color = AcadApplication.GetInterfaceObject("AutoCAD.AcCmColor." & Left(AcadApplication.Version, 2)) color.SetRGB 80, 100, 244 Dim line As AcadLine Dim startPoint(0 To 2) As Double Dim endPoint(0 To 2) As Double startPoint(0) = 1#: startPoint(1) = 1#: startPoint(2) = 0# endPoint(0) = 5#: endPoint(1) = 5#: endPoint(2) = 0# Set line = ThisDrawing.ModelSpace.AddLine(startPoint, endPoint) ZoomAll line.TrueColor = color Dim retcolor As AcadAcCmColor Set retcolor = line.TrueColor MsgBox "Red = " & retcolor.Red & vbLf & _ "Green = " & retcolor.Green & vbLf & _ "Blue = " & retcolor.Blue End Sub Visual LISP: (vl-load-com) (defun c:Example_SetRGB() ;; This example draws a line and returns the RGB values (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) (setq color (vlax-create-object (strcat "AutoCAD.AcCmColor." (substr (getvar "ACADVER") 1 2)))) (vla-SetRGB color 80 100 244) (setq startPoint (vlax-3d-point 1 1 0) endPoint (vlax-3d-point 5 5 0)) (setq modelSpace (vla-get-ModelSpace doc)) (setq lineObj (vla-AddLine modelSpace startPoint endPoint)) (vla-ZoomAll acadObj) (vla-put-TrueColor lineObj color) (setq retcolor (vla-get-TrueColor lineObj)) (alert (strcat "Red = " (itoa (vla-get-Red retcolor)) "\nGreen = " (itoa (vla-get-Green retcolor)) "\nBlue = " (itoa (vla-get-Blue retcolor)))) ) |
GMT+8, 2024-6-10 15:39
