设置边在给定索引处的可见性状态。 支持的平台:仅窗口 签名工 务 局: object.SetInvisibleEdge Index, State
返回值(RetVal)无返回值。 言论您可以创建所有边都不可见的对象。它不会出现在线框演示文稿中,但可以隐藏线条图中的材料。它不会出现在着色渲染中。3DFace 必须调用该方法才能在图形中显示任何可见性更改。Regen 例子工 务 局: Sub Example_SetInvisibleEdge() ' This example creates a 3D face in model space. ' It then toggles the visibility of the first edge. Dim faceObj As Acad3DFace Dim point1(0 To 2) As Double Dim point2(0 To 2) As Double Dim point3(0 To 2) As Double Dim point4(0 To 2) As Double ' Define the four coordinates of the face point1(0) = 1#: point1(1) = 1#: point1(2) = 0# point2(0) = 5#: point2(1) = 1#: point2(2) = 1# point3(0) = 1#: point3(1) = 10#: point3(2) = 0# point4(0) = 5#: point4(1) = 5#: point4(2) = 1# ' Create the 3DFace object in model space Set faceObj = ThisDrawing.ModelSpace.Add3DFace(point1, point2, point3, point4) ZoomAll ' Find the current visibility status of the first edge of the face Dim visStatus As Boolean visStatus = faceObj.GetInvisibleEdge(0) MsgBox "The first face is currently " & IIf(faceObj.GetInvisibleEdge(0), "visible.", "invisible."), , "GetInvisibleEdge Example" ' Toggle the visibility of the first edge of the face faceObj.SetInvisibleEdge 0, Not (visStatus) ThisDrawing.Regen False MsgBox "The first face is now " & IIf(faceObj.GetInvisibleEdge(0), "visible.", "invisible."), , "GetInvisibleEdge Example" End Sub Visual LISP: (vl-load-com) (defun c:Example_SetInvisibleEdge() ;; This example creates a 3D face in model space. ;; It then toggles the visibility of the first edge. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Define the four coordinates of the face (setq point1 (vlax-3d-point 1 1 0) point2 (vlax-3d-point 5 1 1) point3 (vlax-3d-point 5 5 1) point4 (vlax-3d-point 1 10 0)) ;; Create the 3DFace object in model space (setq modelSpace (vla-get-ModelSpace doc)) (setq faceObj (vla-Add3DFace modelSpace point1 point2 point3 point4)) (vla-ZoomAll acadObj) ;; Find the current visibility status of the first edge of the face (setq visStatus (vla-GetInvisibleEdge faceObj 0)) (alert (strcat "The first face is currently " (if (= visStatus :vlax-true) "visible." "invisible."))) ;; Toggle the visibility of the first edge of the face (vla-SetInvisibleEdge faceObj 0 (if (= visStatus :vlax-true) :vlax-false :vlax-true)) (vla-Regen doc :vlax-false) (alert (strcat "The first face is now " (if (= (vla-GetInvisibleEdge faceObj 0) :vlax-true) "visible." "invisible."))) ) |
GMT+8, 2024-6-11 04:34
