设置列的名称。 支持的平台:仅窗口 签名工 务 局: object.SetColumnName nIndex, name
返回值(RetVal)无返回值。 言论没有额外的评论。 例子工 务 局: Sub Example_ColumnName() ' This example adds a table in model space and sets and gets a column name Dim MyModelSpace As AcadModelSpace Set MyModelSpace = ThisDrawing.ModelSpace Dim pt(2) As Double Dim MyTable As AcadTable Dim cName As String Set MyTable = MyModelSpace.AddTable(pt, 5, 5, 10, 30) Call MyTable.SetColumnName(2, "Test Name") MsgBox "The column name is: " & vbCrLf & _ MyTable.GetColumnName(2) ZoomExtents End Sub Visual LISP: (vl-load-com) (defun c:Example_ColumnName() ;; This example adds a table in model space and sets and gets a column name (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) (setq pt (vlax-3d-point 0 0 0)) (setq modelSpace (vla-get-ModelSpace doc)) (setq MyTable (vla-AddTable modelSpace pt 5 5 10 30)) (vla-SetColumnName MyTable 2 "Test Name") (alert (strcat "The column name is: \n" (vla-GetColumnName MyTable 2))) (vla-ZoomExtents acadObj) ) |
GMT+8, 2024-6-10 16:44
