创建一个区域,该区域表示由三个点和实体定义的平面的交点。 支持的平台:仅窗口 签名工 务 局: RetVal = object.SectionSolid(Point1, Point2, Point3)
言论例子工 务 局: Sub Example_SectionSolid() ' This example creates a box in model space. ' It then sections the box based on a plane ' defined by three points. The section is returned ' as a region. Dim boxObj As Acad3DSolid Dim length As Double, width As Double, height As Double Dim center(0 To 2) As Double ' Define the box center(0) = 5#: center(1) = 5#: center(2) = 0 length = 5#: width = 7: height = 10# ' Create the box (3DSolid) object in model space Set boxObj = ThisDrawing.ModelSpace.AddBox(center, length, width, height) ' Define the section plane with three points Dim sectionPt1(0 To 2) As Double Dim sectionPt2(0 To 2) As Double Dim sectionPt3(0 To 2) As Double sectionPt1(0) = 1.5: sectionPt1(1) = 7.5: sectionPt1(2) = 0 sectionPt2(0) = 1.5: sectionPt2(1) = 7.5: sectionPt2(2) = 10 sectionPt3(0) = 8.5: sectionPt3(1) = 2.5: sectionPt3(2) = 10 ' Section the box Dim sectionObj As AcadRegion Set sectionObj = boxObj.SectionSolid(sectionPt1, sectionPt2, sectionPt3) ' Change the viewing direction of the viewport Dim NewDirection(0 To 2) As Double NewDirection(0) = -1: NewDirection(1) = -1: NewDirection(2) = 1 ThisDrawing.ActiveViewport.direction = NewDirection ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport ZoomAll End Sub Visual LISP: (vl-load-com) (defun c:Example_SectionSolid() ;; This example creates a box in model space. ;; It then sections the box based on a plane ;; defined by three points. The section is returned ;; as a region. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Define the box (setq center (vlax-3d-point 5 5 0) boxLength 5 boxWidth 7 boxHeight 10) ;; Create the box (3DSolid) object in model space (setq modelSpace (vla-get-ModelSpace doc)) (setq boxObj (vla-AddBox modelSpace center boxLength boxWidth boxHeight)) ;; Define the section plane with three points (setq sectionPt1 (vlax-3d-point 1.5 7.5 0) sectionPt2 (vlax-3d-point 1.5 7.5 10) sectionPt3 (vlax-3d-point 8.5 2.5 10)) ;; Section the box (setq sectionObj (vla-SectionSolid boxObj sectionPt1 sectionPt2 sectionPt3)) ;; Change the viewing direction of the viewport (setq NewDirection (vlax-3d-point -1 -1 1)) (setq activeViewport (vla-get-ActiveViewport doc)) (vla-put-Direction activeViewport NewDirection) (vla-put-ActiveViewport doc activeViewport) (vla-ZoomAll acadObj) ) |
GMT+8, 2024-6-11 03:45
