从应用程序对象运行 VBA 宏。 支持的平台:仅窗口 签名工 务 局: object.RunMacro MacroPath
返回值(RetVal)无返回值。 言论若要将宏与弹出菜单或工具栏项相关联,请使用属性。Macro 例子工 务 局: Sub Example_RunMacro() ' This example loads a DVB file and runs a macro ' contained in the file using the RunMacro method. ' ' This example uses a DVB file named drawline.dvb. ' You should change the example to use a file on your computer. ' ' * Note: If you open a DVB file and then run the example to load it, there will be an error ' when the DVB file is unloaded. Dim FileName As String FileName = "c:\drawline.dvb" ' Load a sample VBA project DVB file LoadDVB FileName ' Run the drawline sample macro RunMacro "Module1.Drawline" ' Unload the drawline VBA project DVB file now that we are done UnloadDVB FileName MsgBox "The DVB file has been run!" End Sub Visual LISP: (vl-load-com) (defun c:Example_RunMacro() ;; This example loads a DVB file and runs a macro ;; contained in the file using the RunMacro method. ;; ;; This example uses a DVB file named drawline.dvb. ;; You should change the example to use a file on your computer. ;; ;; * Note: If you open a DVB file and then run the example to load it, there will be an error ;; when the DVB file is unloaded. (setq acadObj (vlax-get-acad-object)) (setq fileName (findfile ".\\Sample\\VBA\\drawline.dvb")) ;; Load a sample VBA project DVB file (vla-LoadDVB acadObj fileName) ;; Run the drawline sample macro (vla-RunMacro acadObj "Module1.Drawline") ;; Unload the drawline VBA project DVB file now that we are done (vla-UnloadDVB acadObj fileName) (alert "The DVB file has been run!") ) |
GMT+8, 2024-6-2 20:53
