恢复一组图层属性设置。 支持的平台:仅窗口 返回值(RetVal)无返回值。 言论该方法使用与保存的设置关联的属性来标识要恢复的图层属性。RestoreMask 例子工 务 局: Sub Example_RestoreLayerSettings() ' The following code restores color and linetype settings ' that were saved as "ColorLineType". Dim oLSM As AcadLayerStateManager Set oLSM = ThisDrawing.Application. _ GetInterfaceObject("AutoCAD.AcadLayerStateManager." & Left(AcadApplication.Version, 2)) oLSM.SetDatabase ThisDrawing.Database oLSM.Restore "ColorLinetype" End Sub Visual LISP: (defun c:Example_Restore() ;; The following code restores color and linetype settings ;; that were saved as "ColorLineType." (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Access the LayerStateManager object. (setq oLSM (vla-GetInterfaceObject acadObj (strcat "AutoCAD.AcadLayerStateManager." (substr (getvar "ACADVER") 1 2)))) (vla-SetDatabase oLSM (vla-get-Database doc)) (vla-Restore oLSM "ColorLinetype") ) |
GMT+8, 2024-6-11 05:46
