从组或选择集中移除指定的项目。 支持的平台:仅窗口 返回值(RetVal)无返回值。 言论从组或选择集中移除的项目将保留在图形中;它们只是不再与组或选择集相关联。此功能模仿方法中的功能,不同之处在于允许您指定要删除的单个项目而不是整个选择集。ClearRemoveItems 此方法与 与 and 方法的不同之处在于它不会从图形中删除对象。DeleteErase 例子工 务 局: Sub Example_RemoveItems() ' This example creates a selection set and several objects. ' It adds the objects to the selection set, and then ' removes two of the objects from the selection set. ' Create the new selection set Dim ssetObj As AcadSelectionSet Set ssetObj = ThisDrawing.SelectionSets.Add("TEST_SELECTIONSET") ' Create a Ray object in model space Dim rayObj As AcadRay Dim basePoint(0 To 2) As Double Dim SecondPoint(0 To 2) As Double basePoint(0) = 3#: basePoint(1) = 3#: basePoint(2) = 0# SecondPoint(0) = 1#: SecondPoint(1) = 3#: SecondPoint(2) = 0# Set rayObj = ThisDrawing.ModelSpace.AddRay(basePoint, SecondPoint) ' Create a polyline object in model space Dim plineObj As AcadLWPolyline Dim points(0 To 5) As Double points(0) = 3: points(1) = 7 points(2) = 9: points(3) = 2 points(4) = 3: points(5) = 5 Set plineObj = ThisDrawing.ModelSpace.AddLightWeightPolyline(points) plineObj.Closed = True ' Create a line object in model space Dim lineObj As AcadLine Dim startPoint(0 To 2) As Double Dim endPoint(0 To 2) As Double startPoint(0) = 0: startPoint(1) = 0: startPoint(2) = 0 endPoint(0) = 2: endPoint(1) = 2: endPoint(2) = 0 Set lineObj = ThisDrawing.ModelSpace.AddLine(startPoint, endPoint) ' Create a circle object in model space Dim circObj As AcadCircle Dim centerPt(0 To 2) As Double Dim radius As Double centerPt(0) = 20: centerPt(1) = 30: centerPt(2) = 0 radius = 3 Set circObj = ThisDrawing.ModelSpace.AddCircle(centerPt, radius) ' Create an ellipse object in model space Dim ellObj As AcadEllipse Dim majAxis(0 To 2) As Double Dim center(0 To 2) As Double Dim radRatio As Double center(0) = 5#: center(1) = 5#: center(2) = 0# majAxis(0) = 10: majAxis(1) = 20#: majAxis(2) = 0# radRatio = 0.3 Set ellObj = ThisDrawing.ModelSpace.AddEllipse(center, majAxis, radRatio) ZoomAll ' Iterate through the model space collection. ' Collect the objects found into an array of objects ' to be added to the selection set. ReDim ssobjs(0 To ThisDrawing.ModelSpace.Count - 1) As AcadEntity Dim I As Integer For I = 0 To ThisDrawing.ModelSpace.Count - 1 Set ssobjs(I) = ThisDrawing.ModelSpace.Item(I) Next ' Add the array of objects to the selection set ssetObj.AddItems ssobjs GoSub LISTOBJS ' Remove two of the objects from the selection set Dim removeObjects(0 To 1) As AcadEntity Set removeObjects(0) = ellObj Set removeObjects(1) = circObj ssetObj.RemoveItems removeObjects MsgBox "The ellipse and circle have been removed from the selection set." GoSub LISTOBJS Exit Sub LISTOBJS: ' List all the objects in the selection set If ssetObj.Count = 0 Then MsgBox "The selection set is empty" Else For I = 0 To ssetObj.Count - 1 MsgBox "The selection set contains: " & ssetObj.Item(I).ObjectName Next End If Return End Sub Visual LISP: (vl-load-com) (defun c:Example_RemoveItems() ;; This example creates a selection set and several objects. ;; It adds the objects to the selection set, and then ;; removes two of the objects from the selection set. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) (setq modelSpace (vla-get-ModelSpace doc)) ;; Create the new selection set (setq ssetObj (vla-Add (vla-get-SelectionSets doc) "TEST_SELECTIONSET")) ;; Create a Ray object in model space (setq basePoint (vlax-3d-point 3 3 0) secondPoint (vlax-3d-point 1 3 0)) (setq rayObj (vla-AddRay modelSpace basePoint SecondPoint)) ;; Create a polyline object in model space (setq points (vlax-make-safearray vlax-vbDouble '(0 . 5))) (vlax-safearray-fill points '(3 7 9 2 3 5 ) ) (setq plineObj (vla-AddLightWeightPolyline modelSpace points)) (vla-put-Closed plineObj :vlax-true) ;; Create a line object in model space (setq startPoint (vlax-3d-point 0 0 0) endPoint (vlax-3d-point 2 2 0)) (setq lineObj (vla-AddLine modelSpace startPoint endPoint)) ;; Create a circle object in model space (setq centerPt (vlax-3d-point 20 30 0) radius 3) (setq circObj (vla-AddCircle modelSpace centerPt radius)) ;; Create an ellipse object in model space (setq center (vlax-3d-point 5 5 0) majAxis (vlax-3d-point 10 20 0) radRatio 0.3) (setq ellObj (vla-AddEllipse modelSpace center majAxis radRatio)) (vla-ZoomAll acadObj) ;; Iterate through the model space collection. ;; Collect the objects found into an array of objects ;; to be added to the selection set. (setq ssobjs (vlax-make-safearray vlax-vbObject (cons 0 (- (vla-get-Count modelSpace) 1)))) (setq cnt 0) (vlax-for each-item modelSpace (vlax-safearray-put-element ssobjs cnt each-item) (setq cnt (1+ cnt)) ) ;; Add the array of objects to the selection set (vla-AddItems ssetObj ssobjs) ;; List all the objects in the selection set (setq I 0) (if (= (vla-get-Count ssetObj) 0) (alert "The selection set is empty") (while (>= (1- (vla-get-Count ssetObj)) I) (alert (strcat "The selection set contains: " (vla-get-ObjectName (vla-Item ssetObj I)))) (setq I (1+ I)) ) ) ;; Remove two of the objects from the selection set (setq removeObjects (vlax-make-safearray vlax-vbObject '(0 . 1))) (vlax-safearray-put-element removeObjects 0 ellObj) (vlax-safearray-put-element removeObjects 1 circObj) (vla-RemoveItems ssetObj removeObjects) (alert "The ellipse and circle have been removed from the selection set.") ;; List all the objects in the selection set (setq I 0) (if (= (vla-get-Count ssetObj) 0) (alert "The selection set is empty") (while (>= (1- (vla-get-Count ssetObj)) I) (alert (strcat "The selection set contains: " (vla-get-ObjectName (vla-Item ssetObj I)))) (setq I (1+ I)) ) ) (vla-Delete ssetObj) ) |
GMT+8, 2024-6-11 05:35
