从字典中删除命名对象。 支持的平台:仅窗口 言论例如,从以下字典中删除名为“FirstKeyword”的对象:
结果在以下字典中:
例子工 务 局: Sub Example_Remove() ' This example creates a dictionary and adds ' a custom object to that dictionary. It then ' removes the object from the dictionary. Dim dictObj As AcadDictionary Set dictObj = ThisDrawing.Dictionaries.Add("TEST_DICTIONARY") ' Load the ObjectARX application that defines the custom object. ' Note: The application listed here does not exist and ' will cause an error when run. Change the application name ' to the path and name of your ObjectARX Application. ThisDrawing.Application.LoadArx "MyARXApp.arx" ' Create the custom object in the dictionary Dim keyName As String Dim className As String Dim customObj As AcadObject keyName = "OBJ1" className = "CAsdkDictObject" Set customObj = dictObj.AddObject(keyName, className) ' Remove the object from the dictionary using the keyName dictObj.Remove keyName End Sub Visual LISP: (vl-load-com) (defun c:Example_Remove() ;; This example creates a dictionary and adds ;; a custom object to that dictionary. It then ;; removes the object from the dictionary. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) (setq dictionaries (vla-get-Dictionaries doc)) (setq dictObj (vla-Add dictionaries "TEST_DICTIONARY")) ;; Load the ObjectARX application that defines the custom object. ;; Note: The application listed here does not exist and ;; will cause an error when run. Change the application name ;; to the path and name of your ObjectARX Application. (vla-LoadArx acadObj "MyARXApp.arx") ;; Create the custom object in the dictionary (setq keyName "OBJ1") (setq className "CAsdkDictObject") (setq customObj (vla-AddObject dictObj keyName className)) ;; Remove the object from the dictionary using the keyName (vla-Remove dictObj keyName) ) |
GMT+8, 2024-6-11 00:39
