重新加载外部参照 (外部参照)。 支持的平台:仅窗口 返回值(RetVal)无返回值。 言论重新加载外部参照时,参照图形的最近保存版本将加载到当前图形中。 例子工 务 局: Sub Example_Reload() On Error GoTo ERRORHANDLER ' Define external reference to be inserted Dim xrefHome As AcadBlock Dim xrefInserted As AcadExternalReference Dim insertionPnt(0 To 2) As Double Dim PathName As String insertionPnt(0) = 1 insertionPnt(1) = 1 insertionPnt(2) = 0 PathName = "c:/AutoCAD/sample/City map.dwg" ' Add the external reference to the block Set xrefInserted = ThisDrawing.ModelSpace. _ AttachExternalReference(PathName, "XREF_IMAGE", _ insertionPnt, 1, 1, 1, 0, False) ZoomAll MsgBox "The external reference is attached." ' Reload the external reference definition ThisDrawing.Blocks.Item(xrefInserted.name).Reload MsgBox "The external reference is reloaded." Exit Sub ERRORHANDLER: MsgBox Err.Description End Sub Visual LISP: (vl-load-com) (defun c:Example_Reload() (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Define external reference to be inserted (setq insertionPnt (vlax-3d-point 1 1 0) pathName (findfile ".\\Sample\\Sheet Sets\\Architectural\\Res\\STAIR1.dwg")) ;; Add the external reference to the block (setq modelSpace (vla-get-ModelSpace doc)) (setq xrefInserted (vla-AttachExternalReference modelSpace pathName "XREF_IMAGE" insertionPnt 1 1 1 0 :vlax-false)) (vla-ZoomAll acadObj) (alert "The external reference is attached.") ;; Unload the external reference definition (vla-Unload (vla-Item (vla-get-Blocks doc) "XREF_IMAGE")) (vla-Regen doc :vlax-true) (alert "The external reference is unloaded.") ;; Reload the external reference definition (vla-Reload (vla-Item (vla-get-Blocks doc) "XREF_IMAGE")) (alert "The external reference is reloaded.") ) |
GMT+8, 2024-6-2 17:36
