在命令行上显示提示符。 支持的平台:仅窗口 返回值(RetVal)无返回值。 言论没有额外的评论。 例子工 务 局: Sub Example_Prompt() ' This example will use the Utility object to display a prompt to the ' AutoCAD command line. To see the results after running the example, ' switch to AutoCAD and look at the command line. ThisDrawing.Utility.Prompt "Press any key..." End Sub Visual LISP: (vl-load-com) (defun c:Example_Prompt() ;; This example will use the Utility object to display a prompt to the ;; AutoCAD command line. To see the results after running the example, ;; switch to AutoCAD and look at the command line. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) (vla-Prompt (vla-get-Utility doc) "Press any key...") ) |
GMT+8, 2024-6-11 04:32
