在距现有对象的指定偏移距离处创建新对象。 支持的平台:仅窗口 签名工 务 局: RetVal = object.Offset(Distance) 返回值(RetVal)类型:变体(对象数组) 由偏移量生成的新创建的对象的数组。 言论对于许多曲线,此操作的结果将是一条新曲线(可能与原始曲线的类型不同)。例如,偏移椭圆将产生样条曲线,因为结果不符合椭圆的方程。在某些情况下,偏移结果可能需要为多条曲线。 原始对象和偏移量为红色的对象。 例子工 务 局: Sub Example_Offset() ' This example creates a lightweight polyline ' and then offsets the polyline. ' Create the polyline Dim plineObj As AcadLWPolyline Dim points(0 To 11) As Double points(0) = 1: points(1) = 1 points(2) = 1: points(3) = 2 points(4) = 2: points(5) = 2 points(6) = 3: points(7) = 2 points(8) = 4: points(9) = 4 points(10) = 4: points(11) = 1 Set plineObj = ThisDrawing.ModelSpace.AddLightWeightPolyline(points) plineObj.Closed = True ZoomAll MsgBox "Offset the polyline by 0.25.", , "Offset Example" ' Offset the polyline Dim offsetObj As Variant offsetObj = plineObj.offset(0.25) ZoomAll MsgBox "Offset completed.", , "Offset Example" End Sub Visual LISP: (vl-load-com) (defun c:Example_Offset() ;; This example creates a lightweight polyline ;; and then offsets the polyline. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Create the polyline (setq points (vlax-make-safearray vlax-vbDouble '(0 . 11))) (vlax-safearray-fill points '(1 1 1 2 2 2 3 2 4 4 4 1 ) ) (setq modelSpace (vla-get-ModelSpace doc)) (setq plineObj (vla-AddLightWeightPolyline modelSpace points)) (vla-put-Closed plineObj :vlax-true) (vla-ZoomAll acadObj) (alert "Offset the polyline by 0.25.") ;; Offset the polyline (setq offsetObj (vla-Offset plineObj 0.25)) (vla-ZoomAll acadObj) (alert "Offset completed.") ) |
GMT+8, 2024-6-10 17:53
