获取当前加载的 ObjectARX 应用程序。 支持的平台:仅窗口 返回值(RetVal)类型:变体 当前加载的 ObjectARX 应用程序的数组。如果当前未加载任何应用程序,则返回空。 言论没有额外的评论。 例子工 务 局: Sub Example_ListARX() ' This example gets all the loaded ObjectARX applications ' Get the list of applications Dim appList As Variant appList = ThisDrawing.Application.ListArx ' Iterate through the list, and display the names, if any. If VarType(appList) <> vbEmpty Then Dim I As Integer For I = LBound(appList) To UBound(appList) MsgBox "ObjectARX application name: " & appList(I) Next Else MsgBox "No ObjectARX applications present." End If End Sub Visual LISP: (vl-load-com) (defun c:Example_ListARX() ;; This example gets all the loaded ObjectARX applications (setq acadObj (vlax-get-acad-object)) ;; Get the list of applications (setq appList (vla-ListArx acadObj)) ;; Iterate through the list, and display the names, if any. (if (/= (vlax-variant-value appList) vlax-vbEmpty) (progn (setq I 0 appList (vlax-variant-value appList)) (while (>= (vlax-safearray-get-u-bound appList 1) I) (alert (strcat "ObjectARX application name: " (vlax-safearray-get-element appList I))) (setq I (1+ I)) ) ) (alert "No ObjectARX applications present.") ) ) |
GMT+8, 2024-6-10 23:58
