初始化 GetKeyword 方法。 支持的平台:仅窗口 签名工 务 局: object.InitializeUserInput Bits [, Keyword]
返回值(RetVal)无返回值。 言论在调用 to 之前,必须使用此方法定义关键字。某些用户输入法除了通常返回的值之外,还可以接受关键字值,前提是已调用此方法来定义关键字。可以接受关键字的用户输入方法是:,,,,,,,和。GetKeywordGetKeywordGetIntegerGetRealGetDistanceGetAngleGetOrientationGetPointGetCorner 例子工 务 局: Sub Example_InitializeUserInput() ' This example prompts for user input of a point. By using the ' InitializeUserInput method to define a keyword list, the example can also ' return keywords entered by the user. AppActivate ThisDrawing.Application.Caption On Error Resume Next ' Define the valid keywords Dim keywordList As String keywordList = "Line Circle" ' Call InitializeUserInput to set up the keywords ThisDrawing.Utility.InitializeUserInput 128, keywordList ' Get the user input Dim returnPnt As Variant returnPnt = ThisDrawing.Utility.GetPoint(, vbLf & "Enter a point [Line/Circle]: ") If Err Then If StrComp(Err.Description, "User input is a keyword", 1) = 0 Then ' One of the keywords was entered Dim inputString As String Err.Clear inputString = ThisDrawing.Utility.GetInput MsgBox "You entered the keyword: " & inputString Else MsgBox "Error selecting the point: " & Err.Description Err.Clear End If Else ' Display point coordinates MsgBox "The WCS of the point is: " & returnPnt(0) & ", " & returnPnt(1) & ", " & returnPnt(2), , "GetInput Example" End If End Sub Visual LISP: (vl-load-com) (defun c:Example_InitializeUserInput() ;; This example prompts for user input of a point. By using the ;; InitializeUserInput method to define a keyword list, it can also ;; return keywords entered by the user. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Define the valid keywords (setq keywordList "Line Circle") ;; Call InitializeUserInput to set up the keywords (vla-InitializeUserInput (vla-get-Utility doc) 128 keywordList) ;; Get the user input (setq returnPntOrErr (vl-catch-all-apply 'vla-GetPoint (list (vla-get-Utility doc) nil "Enter a point [Line/Circle]: "))) (if (= (type returnPntOrErr)'VL-CATCH-ALL-APPLY-ERROR) (progn (if (= (vl-catch-all-error-message returnPntOrErr) "Automation Error. User input is a keyword") (progn (setq inputString (vla-GetInput (vla-get-Utility doc))) (alert (strcat "You entered the keyword: " inputString)) ) (alert "User pressed ESC or unknown input was provided.") ) ) ;; Display point coordinates (progn (setq returnPnt (vlax-safearray->list (vlax-variant-value returnPntOrErr))) (alert (strcat "The WCS of the point is: " (rtos (nth 0 returnPnt) 2) ", " (rtos (nth 1 returnPnt) 2) ", " (rtos (nth 2 returnPnt) 2))) ) ) ) |
GMT+8, 2024-6-2 21:47
