获取定义要绘制的布局部分的坐标。 支持的平台:仅窗口 签名工 务 局: object.GetWindowToPlot LowerLeft, UpperRight 返回值(RetVal)无返回值。 言论窗口坐标取自原点。 这些值的单位由属性指定。PaperUnits 必须设置属性才能将这些坐标用于绘图。PlotTypeacWindow 例子工 务 局: Sub Example_GetWindowToPlot() ' This example allows the user to define an area in the current layout to plot ' and displays a plot preview of the defined area. ' ' * Note: You will have to exit the plot preview ' before the VBA example will stop and control will be returned AppActivate ThisDrawing.Application.Caption Dim point1 As Variant, point2 As Variant ' Get first point in window point1 = ThisDrawing.Utility.GetPoint(, "Click the lower-left of the window to plot.") ReDim Preserve point1(0 To 1) ' Change this to a 2D array by removing the Z position ' Get second point in window point2 = ThisDrawing.Utility.GetPoint(, "Click the upper-right of the window to plot.") ReDim Preserve point2(0 To 1) ' Change this to a 2D array by removing the Z position ' Send information about window to current layout ThisDrawing.ActiveLayout.SetWindowToPlot point1, point2 ' Read back window information ThisDrawing.ActiveLayout.GetWindowToPlot point1, point2 MsgBox "Press any key to plot the following window:" & vbCrLf & vbCrLf & _ "Lower Left: " & point1(0) & ", " & point1(1) & vbCrLf & _ "Upper Right: " & point2(0) & ", " & point2(1) ' Make sure the instruction is to plot a view, not some other plot style ThisDrawing.ActiveLayout.PlotType = acWindow ' Send Plot To Window ThisDrawing.ActiveLayout.ConfigName = "DWG to PDF.pc3" ThisDrawing.Plot.DisplayPlotPreview acFullPreview End Sub Visual LISP: (vl-load-com) (defun c:Example_GetWindowToPlot() ;; This example allows the user to define an area in the current layout to plot ;; and displays a plot preview of the defined area. ;; ;; * Note: You will have to exit the plot preview ;; before the VBA example will stop and control will be returned (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Get first point in window (setq point1 (vlax-variant-value (vla-GetPoint (vla-get-Utility doc) nil "Click the lower-left of the window to plot."))) ;; Change this to a 2D array by removing the Z position (setq pointTemp1 (vlax-make-safearray vlax-vbDouble '(0 . 1))) (vlax-safearray-put-element pointTemp1 0 (vlax-safearray-get-element point1 0)) (vlax-safearray-put-element pointTemp1 1 (vlax-safearray-get-element point1 1)) ;; Get second point in window (setq point2 (vlax-variant-value (vla-GetCorner (vla-get-Utility doc) point1 "Click the upper-right of the window to plot."))) ;; Change this to a 2D array by removing the Z position (setq pointTemp2 (vlax-make-safearray vlax-vbDouble '(0 . 1))) (vlax-safearray-put-element pointTemp2 0 (vlax-safearray-get-element point2 0)) (vlax-safearray-put-element pointTemp2 1 (vlax-safearray-get-element point2 1)) ;; Send information about window to current layout (vla-SetWindowToPlot (vla-get-ActiveLayout doc) pointTemp1 pointTemp2) ;; Read back window information (vla-GetWindowToPlot (vla-get-ActiveLayout doc) 'point1 'point2) (setq point1 (vlax-safearray->list point1) point2 (vlax-safearray->list point2)) (alert (strcat "Press any key to plot the following window:" "\nLower Left: " (rtos (nth 0 point1) 2) ", " (rtos (nth 1 point1) 2) "\nUpper Right: " (rtos (nth 0 point2) 2) ", " (rtos (nth 1 point2) 2))) ;; Make sure the instruction is to plot a view, not some other plot style (vla-put-PlotType (vla-get-ActiveLayout doc) acWindow) ;; Send Plot To Window - A plot device must be set before a preview can be created (vla-DisplayPlotPreview (vla-get-Plot doc) acFullPreview) ) |
GMT+8, 2024-6-10 19:13
