获取视区的对齐间距。 支持的平台:仅窗口 签名工 务 局: object.GetSnapSpacing XSpacing, YSpacing 返回值(RetVal)无返回值。 言论没有额外的评论。 例子工 务 局: Sub Example_GetSnapSpacing() ' This example finds the current Snap spacing, and changes that spacing. ' Find the current active Model space viewport Dim viewportObj As AcadViewport Set viewportObj = ThisDrawing.ActiveViewport ' Turn on Snap spacing and reset the viewport. viewportObj.SnapOn = True ThisDrawing.ActiveViewport = viewportObj ' Find the current Snap spacing Dim XSpacing As Double Dim YSpacing As Double viewportObj.GetSnapSpacing XSpacing, YSpacing MsgBox "X =" & XSpacing & ", Y =" & YSpacing, Title:="GetSnapSpacing Example" ' Change the Snap spacing XSpacing = XSpacing * 0.5 YSpacing = YSpacing * 0.5 viewportObj.SetSnapSpacing XSpacing, YSpacing ThisDrawing.ActiveViewport = viewportObj MsgBox "X =" & XSpacing & ", Y =" & YSpacing, Title:="GetSnapSpacing Example" End Sub Visual LISP: (vl-load-com) (defun c:Example_GetSnapSpacing() ;; This example finds the current Snap spacing, and changes that spacing. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Find the current active Model space viewport (setq viewportObj (vla-get-ActiveViewport doc)) ;; Turn on Snap spacing and reset the viewport. (vla-put-SnapOn viewportObj :vlax-true) (vla-put-ActiveViewport doc viewportObj) ;; Find the current Snap spacing (vla-GetSnapSpacing viewportObj 'XSpacing 'YSpacing) (alert (strcat "X =" (rtos XSpacing 2) ", Y =" (rtos YSpacing 2))) ;; Change the Snap spacing (vla-SetSnapSpacing viewportObj (* XSpacing 0.5) (* YSpacing 0.5)) (vla-put-ActiveViewport doc viewportObj) (vla-GetSnapSpacing viewportObj 'XSpacing 'YSpacing) (alert (strcat "X =" (rtos XSpacing 2) ", Y =" (rtos YSpacing 2))) ) |
GMT+8, 2024-6-10 19:19
