获取单元格或单元格样式的旋转值。 支持的平台:仅窗口 签名 - 表工 务 局: RetVal = object.GetRotation(nRow, nCol, nContent)
签名 - 表格样式工 务 局: RetVal = object.GetRotation(StringCellStyle)
返回值(RetVal)类型:双 单元格或单元格样式的旋转值。 言论没有额外的评论。 例子工 务 局: Sub Example_CellClass() ' This example creates a TableStyle object and sets values for ' the style classes and formatting. Dim dictionaries As AcadDictionaries Set dictionaries = ThisDrawing.Database.dictionaries Dim dictObj As AcadDictionary Set dictObj = dictionaries.Item("acad_tablestyle") ' Create the custom TableStyle object in the dictionary Dim keyName As String Dim className As String Dim customObj As IAcadTableStyle keyName = "NewStyle" className = "AcDbTableStyle" Set customObj = dictObj.AddObject(keyName, className) customObj.Name = "NewStyle" customObj.Description = "New Style for My Tables" customObj.CreateCellStyle ("NewTestStyle") Dim cellTestFormat As String customObj.SetCellClass "NewTestStyle", 4 customObj.SetRotation "NewTestStyle", 8.4 MsgBox "The cell class is " & customObj.GetCellClass("NewTestStyle") & _ " the cell rotation is " & customObj.GetRotation("NewTestStyle") End Sub Visual LISP: (vl-load-com) (defun c:Example_CellClass() ;; This example creates a TableStyle object and sets values for ;; the style classes and formatting. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) (setq dictionaries (vla-get-Dictionaries doc)) (setq dictObj (vla-Item dictionaries "acad_tablestyle")) ;; Create the custom TableStyle object in the dictionary (setq keyName "NewStyle" className "AcDbTableStyle") (setq customObj (vla-AddObject dictObj keyName className)) (vla-put-Name customObj "NewStyle") (vla-put-Description customObj "New Style for My Tables") (vla-CreateCellStyle customObj "NewTestStyle") (vla-SetCellClass customObj "NewTestStyle" 4) (vla-SetRotation customObj "NewTestStyle" 8.4) (alert (strcat "The cell class is " (itoa (vla-GetCellClass customObj "NewTestStyle")) " and the cell rotation is " (rtos (vla-GetRotation customObj "NewTestStyle") 2) "." ) ) ) |
( 苏ICP备2022047690号-1 )
GMT+8, 2024-6-11 03:22
