获取 AutoCAD 在其中查找外部参照文件的目录。 支持的平台:仅窗口 签名工 务 局: RetVal = object.GetProjectFilePath(ProjectName)
返回值(RetVal)类型:字符串 AutoCAD 在其中查找外部参照文件的目录。 言论没有额外的评论。 例子工 务 局: Sub Example_GetProjectFilePath() ' This example finds the current project file information. Dim preferences As AcadPreferences Set preferences = ThisDrawing.Application.preferences ' Get the current project file information Dim currProjPath As String Dim currProjName As Variant currProjName = ThisDrawing.GetVariable("PROJECTNAME") If currProjName <> "" Then currProjPath = preferences.Files.GetProjectFilePath(currProjName) End If If currProjPath = "" Then MsgBox "There is no current project file or path. ", , "GetProjectFilePath Example" Else MsgBox "The current project file path is: " & currProjPath, , "GetProjectFilePath Example" End If End Sub Visual LISP: (vl-load-com) (defun c:Example_GetProjectFilePath() ;; This example finds the current project file information. (setq acadObj (vlax-get-acad-object)) (setq preferences (vla-get-Preferences acadObj)) ;; Get the current project file information (setq currProjName (vlax-variant-value (vla-GetVariable doc "PROJECTNAME"))) (if (/= currProjName "") (progn (setq currProjPath (vla-GetProjectFilePath (vla-get-Files preferences) currProjName)) (alert (strcat "The current project file path is: " currProjPath)) ) (alert "There is no current project file or path.") ) ) |
GMT+8, 2024-6-11 03:50
