获取布局或打印配置的边距。 支持的平台:仅窗口 签名工 务 局: object.GetPaperMargins LowerLeft, UpperRight 返回值(RetVal)无返回值。 言论打印原点从纸张边缘偏移此处指定的边距。 这些值的单位由属性指定。PaperUnits 例子工 务 局: Sub Example_GetPaperMargins() ' This example will access the Layouts collection for the current drawing ' and list the plot size based on the margins returned from the GetPaperMargins ' property for each Layout except model space. Dim Layouts As AcadLayouts, Layout As ACADLayout Dim msg As String Dim Measurement As String Dim MarginLowerLeft As Variant, MarginUpperRight As Variant Dim PaperHeight As Double, PaperWidth As Double Dim PlotHeight As Double, PlotWidth As Double ' Get layouts collection from document object Set Layouts = ThisDrawing.Layouts msg = vbCrLf & vbCrLf ' Start with a space ' Get the margin information of every layout in this drawing For Each Layout In Layouts ' Skip model space If Layout.name = "Model" Then GoTo NEXT_LAYOUT ThisDrawing.ActiveLayout = Layout msg = msg & Layout.name & vbCrLf ' Get paper size and margin information Layout.GetPaperMargins MarginLowerLeft, MarginUpperRight Layout.GetPaperSize PaperWidth, PaperHeight ' Do plot area calculations PlotWidth = PaperWidth - (MarginUpperRight(0) - MarginLowerLeft(0)) PlotHeight = PaperHeight - (MarginUpperRight(1) - MarginLowerLeft(1)) ' Are we using inches or millimeters Measurement = " millimeter(s)" ' Format for display msg = msg & vbTab & "The paper size for this layout is: " & PaperWidth & " X " & PaperHeight & Measurement & vbCrLf & vbCrLf msg = msg & vbTab & "The paper margins are: " & vbCrLf & _ vbTab & vbTab & "Left" & vbTab & "(" & MarginLowerLeft(0) & ")" & Measurement & vbCrLf & _ vbTab & vbTab & "Right" & vbTab & "(" & MarginUpperRight(0) & ")" & Measurement & vbCrLf & _ vbTab & vbTab & "Top" & vbTab & "(" & MarginUpperRight(1) & ")" & Measurement & vbCrLf & _ vbTab & vbTab & "Bottom" & vbTab & "(" & MarginLowerLeft(1) & ")" & Measurement & vbCrLf & vbCrLf msg = msg & vbTab & "The paper plot area for this layout is: " & PlotWidth & " X " & PlotHeight & Measurement & vbCrLf msg = msg & "_____________________" & vbCrLf NEXT_LAYOUT: Next ' Display paper size and margin information MsgBox "Paper plot information for the current drawing is: " & msg End Sub Visual LISP: (vl-load-com) (defun c:Example_GetPaperMargins() ;; This example will access the Layouts collection for the current drawing ;; and list the plot size based on the margins returned from the GetPaperMargins ;; property for each Layout except model space. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Get layouts collection from document object (setq Layouts (vla-get-Layouts doc)) (setq msg "") ;; Start with a space ;; Get the margin information of every layout in this drawing (vlax-for Layout Layouts ;; Skip model space (if (/= (vla-get-Name Layout) "Model") (progn (vla-put-ActiveLayout doc Layout) (setq msg (strcat msg (vla-get-Name Layout) "\n")) ;; Get paper size and margin information (vla-GetPaperMargins Layout 'MarginLowerLeft 'MarginUpperRight) (vla-GetPaperSize Layout 'PaperWidth 'PaperHeight) ;; Do plot area calculations (setq PlotWidth (- PaperWidth (- (vlax-safearray-get-element MarginUpperRight 0) (vlax-safearray-get-element MarginLowerLeft 0)))) (setq PlotHeight (- PaperHeight (- (vlax-safearray-get-element MarginUpperRight 1) (vlax-safearray-get-element MarginLowerLeft 1)))) ;; Are we using inches or millimeters (setq Measurement " millimeter(s)") ;; Format for display (setq msg (strcat msg "The paper size for this layout is: " (rtos PaperWidth 2) " X " (rtos PaperHeight 2) Measurement "\n\n")) (setq msg (strcat msg " The paper margins are: \n" " Left (" (rtos (vlax-safearray-get-element MarginLowerLeft 0) 2) ")" Measurement "\n" " Right (" (rtos (vlax-safearray-get-element MarginUpperRight 0) 2) ")" Measurement "\n" " Top (" (rtos (vlax-safearray-get-element MarginUpperRight 1) 2) ")" Measurement "\n" " Bottom (" (rtos (vlax-safearray-get-element MarginLowerLeft 1) 2) ")" Measurement "\n\n")) (setq msg (strcat msg "The paper plot area for this layout is: " (rtos PlotWidth 2) " X " (rtos PlotHeight 2) Measurement "\n")) (setq msg (strcat msg "_____________________\n")) ) ) ) ;; Display paper size and margin information (alert (strcat "Paper plot information for the current drawing is: " msg)) ) |
( 苏ICP备2022047690号-1 )
GMT+8, 2024-6-10 22:42
