获取给定索引处的填充循环。 支持的平台:仅窗口 签名工 务 局: object.GetLoopAt Index, Loop
返回值(RetVal)无返回值。 言论没有额外的评论。 例子工 务 局: Sub Example_GetLoopAt() ' This example creates an associative hatch in model space. ' It then finds the objects that make up the first loop of the hatch. Dim hatchObj As AcadHatch Dim patternName As String Dim PatternType As Long Dim bAssociativity As Boolean ' Define the hatch patternName = "ANSI31" PatternType = 0 bAssociativity = True ' Create the associative Hatch object Set hatchObj = ThisDrawing.ModelSpace.AddHatch(PatternType, patternName, bAssociativity) ' Create the outer loop for the hatch. ' An arc and a line are used to create a closed loop. Dim outerLoop(0 To 1) As AcadEntity Dim center(0 To 2) As Double Dim radius As Double Dim startAngle As Double Dim endAngle As Double center(0) = 5: center(1) = 3: center(2) = 0 radius = 3 startAngle = 0 endAngle = 3.141592 Set outerLoop(0) = ThisDrawing.ModelSpace.AddArc(center, radius, startAngle, endAngle) Set outerLoop(1) = ThisDrawing.ModelSpace.AddLine(outerLoop(0).startPoint, outerLoop(0).endPoint) ' Append the outer loop to the hatch object hatchObj.AppendOuterLoop (outerLoop) ' Append the first circle as one inner loop Dim innerLoop1(0) As AcadEntity center(0) = 5: center(1) = 4.5: center(2) = 0 radius = 1 Set innerLoop1(0) = ThisDrawing.ModelSpace.AddCircle(center, radius) hatchObj.AppendInnerLoop (innerLoop1) ' Append the second circle as the other inner loop Dim innerLoop2(0) As AcadEntity radius = 0.5 Set innerLoop2(0) = ThisDrawing.ModelSpace.AddCircle(center, radius) hatchObj.AppendInnerLoop (innerLoop2) ' Evaluate and display the hatch hatchObj.Evaluate ThisDrawing.Regen True ' Find the objects that make up the first loop Dim loopObjs As Variant hatchObj.GetLoopAt 0, loopObjs ' Find the types of the objects in the loop Dim I As Integer Dim objName As String objName = "" For I = LBound(loopObjs) To UBound(loopObjs) objName = objName & loopObjs(I).EntityName & ", " Next MsgBox "The objects in the first loop of the hatch are: " & objName, , "GetLoopAt Example" End Sub Visual LISP: (vl-load-com) (defun c:Example_GetLoopAt() ;; This example creates an associative hatch in model space. ;; It then finds the objects that make up the first loop of the hatch. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) (setq modelSpace (vla-get-ModelSpace doc)) ;; Define the hatch (setq patternName "ANSI31" patternType acHatchPatternTypePreDefined bAssociativity :vlax-true) ;; Create the associative Hatch object (setq modelSpace (vla-get-ModelSpace doc)) (setq hatchObj (vla-AddHatch modelSpace patternType patternName bAssociativity acHatchObject)) ;; Create the outer loop for the hatch. ;; An arc and a line are used to create a closed loop. (setq center (vlax-3d-point 5 3 0) radius 3 startAngle 0 endAngle 3.141592) (setq arcObj (vla-AddArc modelSpace center radius startAngle endAngle)) (setq lineObj (vla-AddLine modelSpace (vla-get-StartPoint arcObj) (vla-get-EndPoint arcObj))) (setq outerLoop (vlax-make-safearray vlax-vbObject '(0 . 1))) (vlax-safearray-put-element outerLoop 0 arcObj) (vlax-safearray-put-element outerLoop 1 lineObj) ;; Append the outer loop to the hatch object (vla-AppendOuterLoop hatchObj outerLoop) ;; Append the first circle as one inner loop (setq center (vlax-3d-point 5 4.5 0) radius 1) (setq innerLoop1 (vlax-make-safearray vlax-vbObject '(0 . 0))) (vlax-safearray-put-element innerLoop1 0 (vla-AddCircle modelSpace center radius)) (vla-AppendInnerLoop hatchObj innerLoop1) ;; Append the second circle as the other inner loop (setq radius 0.5) (setq innerLoop2 (vlax-make-safearray vlax-vbObject '(0 . 0))) (vlax-safearray-put-element innerLoop2 0 (vla-AddCircle modelSpace center radius)) (vla-AppendInnerLoop hatchObj innerLoop2) ;; Evaluate and display the hatch (vla-Evaluate hatchObj) (vla-Regen doc :vlax-true) ;; Find the objects that make up the first loop (vla-GetLoopAt hatchObj 0 'loopObjs) ;; Find the types of the objects in the loop (setq I 0 objName "") (while (>= (vlax-safearray-get-u-bound loopObjs 1) I) (setq objName (strcat objName (vla-get-ObjectName (vlax-safearray-get-element loopObjs I)) ", ")) (setq I (1+ I)) ) (alert (strcat "The objects in the first loop of the hatch are: " objName)) ) |
GMT+8, 2024-6-10 20:13
