获取给定索引处 3DFace 对象边缘的可见性设置。 支持的平台:仅窗口 签名工 务 局: RetVal = object.GetInvisibleEdge(Index)
返回值(RetVal)类型:布尔
言论没有额外的评论。 例子工 务 局: Sub Example_GetInvisibleEdge() ' This example creates a 3D face in model space. ' It then toggles the visibility of the first edge. Dim faceObj As Acad3DFace Dim point1(0 To 2) As Double Dim point2(0 To 2) As Double Dim point3(0 To 2) As Double Dim point4(0 To 2) As Double ' Define the four coordinates of the face point1(0) = 1#: point1(1) = 1#: point1(2) = 0# point2(0) = 5#: point2(1) = 1#: point2(2) = 1# point3(0) = 5#: point3(1) = 5#: point3(2) = 1# point4(0) = 1#: point4(1) = 10#: point4(2) = 0# ' Create the 3DFace object in model space Set faceObj = ThisDrawing.ModelSpace.Add3DFace(point1, point2, point3, point4) ZoomAll ' Find the current visibility status of the first edge of the face Dim visStatus As Boolean visStatus = faceObj.GetInvisibleEdge(0) MsgBox "The first face is currently " & IIf(faceObj.GetInvisibleEdge(0), "visible.", "invisible."), , "GetInvisibleEdge Example" ' Toggle the visibility of the first edge of the face faceObj.SetInvisibleEdge 0, Not (visStatus) ThisDrawing.Regen False MsgBox "The first face is now " & IIf(faceObj.GetInvisibleEdge(0), "visible.", "invisible."), , "GetInvisibleEdge Example" End Sub Visual LISP: (vl-load-com) (defun c:Example_GetInvisibleEdge() ;; This example creates a 3D face in model space. ;; It then toggles the visibility of the first edge. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Define the four coordinates of the face (setq point1 (vlax-3d-point 1 1 0) point2 (vlax-3d-point 5 1 1) point3 (vlax-3d-point 5 5 1) point4 (vlax-3d-point 1 10 0)) ;; Create the 3DFace object in model space (setq modelSpace (vla-get-ModelSpace doc)) (setq faceObj (vla-Add3DFace modelSpace point1 point2 point3 point4)) (vla-ZoomAll acadObj) ;; Find the current visibility status of the first edge of the face (setq visStatus (vla-GetInvisibleEdge faceObj 0)) (alert (strcat "The first face is currently " (if (= visStatus :vlax-true) "visible." "invisible."))) ;; Toggle the visibility of the first edge of the face (vla-SetInvisibleEdge faceObj 0 (if (= visStatus :vlax-true) :vlax-false :vlax-true)) (vla-Regen doc :vlax-false) (alert (strcat "The first face is now " (if (= (vla-GetInvisibleEdge faceObj 0) :vlax-true) "visible." "invisible."))) ) |
GMT+8, 2024-6-2 19:16
