返回块中的所有对象,按绘制顺序排序,底部对象排在最前面。 支持的平台:仅窗口 签名工 务 局: object.GetFullDrawOrder Objects, honorSortentsSysvar 返回值(RetVal)无返回值。 言论没有额外的评论。 例子工 务 局: Sub Example_SortentsTable() ' This example creates a SortentsTable object and ' changes the draw order. ' Set drawing to display lineweights and create a True Color object Dim ACADPref As AcadDatabasePreferences Set ACADPref = ThisDrawing.preferences ACADPref.LineWeightDisplay = True Dim MyColorObjOne As AcadAcCmColor Set MyColorObjOne = AcadApplication.GetInterfaceObject("AutoCAD.AcCmColor." & Left(AcadApplication.Version, 2)) Call MyColorObjOne.SetRGB(80, 100, 244) ' Draw a polyline Dim plineObj As AcadPolyline Dim points(0 To 8) As Double points(0) = 4: points(1) = 4: points(2) = 0 points(3) = 3: points(4) = 5: points(5) = 0 points(6) = 6: points(7) = 20: points(8) = 0 Set plineObj = ThisDrawing.ModelSpace.AddPolyline(points) plineObj.Lineweight = acLnWt211 Call MyColorObjOne.SetRGB(90, 110, 150) plineObj.TrueColor = MyColorObjOne ' Draw a line Dim lineObj As AcadLine Dim startPoint(0 To 2) As Double Dim endPoint(0 To 2) As Double startPoint(0) = 5: startPoint(1) = 13: startPoint(2) = 0 endPoint(0) = 5: endPoint(1) = 27: endPoint(2) = 0 Set lineObj = ThisDrawing.ModelSpace.AddLine(startPoint, endPoint) lineObj.Lineweight = acLnWt211 Call MyColorObjOne.SetRGB(50, 80, 230) lineObj.TrueColor = MyColorObjOne ' Draw a circle Dim circleObj As AcadCircle Dim centerPoint(0 To 2) As Double Dim radius As Double centerPoint(0) = 10: centerPoint(1) = 15: centerPoint(2) = 0# radius = 5# Set circleObj = ThisDrawing.ModelSpace.AddCircle(centerPoint, radius) circleObj.Lineweight = acLnWt211 Call MyColorObjOne.SetRGB(60, 200, 220) circleObj.TrueColor = MyColorObjOne ZoomAll AcadApplication.Update ' Get an extension dictionary and, if necessary, add a SortentsTable object Dim eDictionary As Object Set eDictionary = ThisDrawing.ModelSpace.GetExtensionDictionary ' Prevent failed GetObject calls from throwing an exception On Error Resume Next Dim sentityObj As Object Set sentityObj = eDictionary.GetObject("ACAD_SORTENTS") On Error GoTo 0 If sentityObj Is Nothing Then ' No SortentsTable object, so add one Set sentityObj = eDictionary.AddObject("ACAD_SORTENTS", "AcDbSortentsTable") End If Dim ObjIds(2) As Long ObjIds(0) = plineObj.ObjectID ObjIds(1) = lineObj.ObjectID ObjIds(2) = circleObj.ObjectID Dim varObject As AcadObject Set varObject = ThisDrawing.ObjectIdToObject(ObjIds(2)) Dim arr(0) As AcadObject Set arr(0) = varObject ' Move the circle object to the bottom sentityObj.MoveToBottom arr AcadApplication.Update End Sub Visual LISP: (vl-load-com) (defun c:Example_SortentsTable() ;; This example creates a SortentsTable object and ;; changes the draw order. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) (setq modelSpace (vla-get-ModelSpace doc)) ;; Set drawing to display lineweights and create a True Color object (vla-put-LineWeightDisplay (vla-get-Preferences doc) :vlax-true) (setq MyColorObjOne (vlax-create-object (strcat "AutoCAD.AcCmColor." (substr (getvar "ACADVER") 1 2)))) (vla-SetRGB MyColorObjOne 80 100 244) ;; Draw a polyline (setq points (vlax-make-safearray vlax-vbDouble '(0 . 8))) (vlax-safearray-fill points '(4 4 0 3 5 0 6 20 0 ) ) (setq plineObj (vla-AddPolyline modelSpace points)) (vla-put-Lineweight plineObj acLnWt211) (vla-SetRGB MyColorObjOne 90 110 150) (vla-put-TrueColor plineObj MyColorObjOne) ;; Draw a line (setq startPoint (vlax-3d-point 5 13 0) endPoint (vlax-3d-point 5 27 0)) (setq lineObj (vla-AddLine modelSpace startPoint endPoint)) (vla-put-Lineweight lineObj acLnWt211) (vla-SetRGB MyColorObjOne 50 80 230) (vla-put-TrueColor lineObj MyColorObjOne) ;; Draw a circle (setq centerPoint (vlax-3d-point 10 15 0) radius 5) (setq circleObj (vla-AddCircle modelSpace centerPoint radius)) (vla-put-Lineweight circleObj acLnWt211) (vla-SetRGB MyColorObjOne 60 200 220) (vla-put-TrueColor circleObj MyColorObjOne) (vla-ZoomAll acadObj) (vla-Update acadObj) ;; Get an extension dictionary and, if necessary, add a SortentsTable object (setq eDictionary (vla-GetExtensionDictionary modelSpace)) ;; Prevent failed GetObject calls from throwing an exception (setq sentityObj (vl-catch-all-apply 'vla-GetObject (list eDictionary "ACAD_SORTENTS"))) (if (= (type sentityObj)'VL-CATCH-ALL-APPLY-ERROR) ;; No SortentsTable object, so add one (setq sentityObj (vla-AddObject eDictionary "ACAD_SORTENTS" "AcDbSortentsTable")) ) (setq ObjIds (vlax-make-safearray vlax-vbLong '(0 . 2))) (vlax-safearray-put-element ObjIds 0 (vla-get-ObjectID plineObj)) (vlax-safearray-put-element ObjIds 1 (vla-get-ObjectID lineObj)) (vlax-safearray-put-element ObjIds 2 (vla-get-ObjectID circleObj)) (setq varObject circleObj) (setq arr (vlax-make-safearray vlax-vbObject '(0 . 0))) (vlax-safearray-put-element arr 0 varObject) ;; Move the circle object to the bottom (vla-MoveToBottom sentityObj arr) (vla-Update acadObj) (vlax-release-object MyColorObjOne) ) |
GMT+8, 2024-6-10 17:38
