返回指定行类型的真彩色值。 支持的平台:仅窗口 签名工 务 局: RetVal = object.GetColor(rowType)
言论没有额外的评论。 例子工 务 局: Sub Example_GetColor() ' This example creates a TableStyle object and sets values for ' the style name and other attributes. Dim dictionaries As AcadDictionaries Set dictionaries = ThisDrawing.Database.dictionaries Dim dictObj As AcadDictionary Set dictObj = dictionaries.Item("acad_tablestyle") ' Get the current TableStyle object Dim tableStyle As AcadTableStyle Set tableStyle = dictObj.Item(ThisDrawing.GetVariable("CTABLESTYLE")) Dim colCurrent As AcadAcCmColor, colRowCurrent As AcadAcCmColor, colNoneCurrent As Boolean Set colCurrent = tableStyle.GetBackgroundColor(AcRowType.acDataRow + AcRowType.acTitleRow) Set colRowCurrent = tableStyle.GetColor(acDataRow) colNoneCurrent = tableStyle.GetBackgroundColorNone(AcRowType.acHeaderRow) MsgBox "Table colors " & vbLf & _ "Background ACI value = " & colCurrent.ColorIndex & vbLf & _ "Row Text ACI value = " & colRowCurrent.ColorIndex & vbLf & _ "Background None = " & colNoneCurrent Dim col As AcadAcCmColor Set col = AcadApplication.GetInterfaceObject("AutoCAD.AcCmColor." & Left(AcadApplication.Version, 2)) col.SetRGB 0, 0, 255 tableStyle.SetBackgroundColor AcRowType.acTitleRow, col col.SetRGB 255, 0, 0 tableStyle.SetColor AcRowType.acDataRow, col If colNoneCurrent = False Then tableStyle.SetBackgroundColorNone AcRowType.acHeaderRow, True Else tableStyle.SetBackgroundColorNone AcRowType.acHeaderRow, False End If Dim colNew As AcadAcCmColor, colRowNew As AcadAcCmColor, colNoneNew As Boolean Set colNew = tableStyle.GetBackgroundColor(AcRowType.acTitleRow) Set colRowNew = tableStyle.GetColor(acDataRow) colNoneNew = tableStyle.GetBackgroundColorNone(acHeaderRow) MsgBox "Table colors " & vbLf & _ "Background ACI value = " & colNew.ColorIndex & vbLf & _ "Row Text ACI value = " & colRowNew.ColorIndex & vbLf & _ "Background None = " & colNoneNew tableStyle.SetBackgroundColor AcRowType.acTitleRow, colCurrent tableStyle.SetColor AcRowType.acDataRow, colRowCurrent tableStyle.SetBackgroundColorNone AcRowType.acHeaderRow, colNoneCurrent MsgBox "Reset the table style back to its original values." End Sub Visual LISP: (vl-load-com) (defun c:Example_GetColor() ;; This example creates a TableStyle object and sets values for ;; the style name and other attributes. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) (setq dictionaries (vla-get-Dictionaries doc)) (setq dictObj (vla-Item dictionaries "acad_tablestyle")) ;; Get the current TableStyle object (setq tableStyle (vla-Item dictObj (vla-GetVariable doc "CTABLESTYLE"))) (setq colCurrent (vla-GetBackgroundColor tableStyle (+ acDataRow acTitleRow))) (setq colRowCurrent (vla-GetColor tableStyle acDataRow)) (setq colNoneCurrent (vla-GetBackgroundColorNone tableStyle acHeaderRow)) (alert (strcat "Table colors \n" "Background ACI value = " (itoa (vla-get-ColorIndex colCurrent)) "\n" "Row Text ACI value = " (itoa (vla-get-ColorIndex colRowCurrent)) "\n" "Background None = " (if (= colNoneCurrent :vlax-true) "True" "False"))) (setq col (vlax-create-object (strcat "AutoCAD.AcCmColor." (substr (getvar "ACADVER") 1 2)))) (vla-SetRGB col 0 0 255) (vla-SetBackgroundColor tableStyle acTitleRow col) (vla-SetRGB col 255 0 0) (vla-SetColor tableStyle acDataRow col) (vla-SetBackgroundColorNone tableStyle acHeaderRow (if (= colNoneCurrent :vlax-true) :vlax-false :vlax-true)) (setq colNew (vla-GetBackgroundColor tableStyle acTitleRow)) (setq colRowNew (vla-GetColor tableStyle acDataRow)) (setq colNoneNew (vla-GetBackgroundColorNone tableStyle acHeaderRow)) (alert (strcat "Table colors \n" "Background ACI value = " (itoa (vla-get-ColorIndex colNew)) "\n" "Row Text ACI value = " (itoa (vla-get-ColorIndex colRowNew)) "\n" "Background None = " (if (= colNoneNew :vlax-true) "True" "False"))) (vla-SetBackgroundColor tableStyle acTitleRow colCurrent) (vla-SetColor tableStyle acDataRow colRowCurrent) (vla-SetBackgroundColorNone tableStyle acHeaderRow colNoneCurrent) (alert "Reset the table style back to its original values.") (vlax-release-object col) ) |
GMT+8, 2024-6-11 01:00
