获取用作工具栏项图标的大小位图。 支持的平台:仅窗口 签名工 务 局: object.GetBitmaps SmallIconName, LargeIconName
返回值(RetVal)无返回值。 言论没有额外的评论。 例子工 务 局: Sub Example_GetBitmaps() ' This example uses MenuGroups to obtain a reference to the AutoCAD main menu. ' It then creates a new Toolbar (TestMenu) and inserts a ToolBarButton ' with a custom icon into it. The menu is automatically shown. ' ' * NOTE: The paths of the icons for the new toolbar should be updated ' before running this example. Dim currMenuGroup As acadMenuGroup Dim newToolBar As AcadToolbar, newToolBarButton As AcadToolbarItem Dim openMacro As String Dim SmallBitmapName As String, LargeBitmapName As String On Error GoTo ERRORTRAP ' Use MenuGroups property to obtain reference to main AutoCAD menu Set currMenuGroup = ThisDrawing.Application.MenuGroups.Item("ACAD") ' Create the new Toolbar in this group Set newToolBar = currMenuGroup.Toolbars.Add("TestMenu") ' Add an item to the new Toolbar and assign an Open macro ' (VBA equivalent of: "ESC ESC _open ") openMacro = Chr(3) & Chr(3) & Chr(95) & "open" & Chr(32) Set newToolBarButton = newToolBar.AddToolbarButton(newToolBar.count + 1, "Open", "Open Macro", openMacro, False) ' Read icon paths for this Toolbar button GoSub READPATHS ' Change the default icon (smile face) for the new toolbar button SmallBitmapName = "c:\AutoCAD\16x16.bmp" ' Use a 16x16 pixel .BMP image LargeBitmapName = "c:\AutoCAD\32x32.bmp" ' Use a 32x32 pixel .BMP image newToolBarButton.SetBitmaps SmallBitmapName, LargeBitmapName ' Read icon paths for this Toolbar button GoSub READPATHS Exit Sub READPATHS: ' Read icon paths for this Toolbar button newToolBarButton.GetBitmaps SmallBitmapName, LargeBitmapName MsgBox "The new Toolbar uses the following icon files: " & _ vbCrLf & vbCrLf & "Small Bitmap: " & SmallBitmapName & vbCrLf & _ "Large Bitmap: " & LargeBitmapName Return ERRORTRAP: MsgBox "The following error has occurred: " & Err.Description End Sub Visual LISP: (vl-load-com) (defun c:Example_GetBitmaps() ;; This example uses MenuGroups to obtain a reference to the AutoCAD main menu. ;; It then creates a new Toolbar (TestMenu) and inserts a ToolBarButton ;; with a custom icon into it. The menu is automatically shown. ;; ;; * NOTE: The paths of the icons for the new toolbar should be updated ;; before running this example. (setq acadObj (vlax-get-acad-object)) (setq currMenuGroup (vla-Item (vla-get-MenuGroups acadObj) 0)) ;; Create the new Toolbar in this group (setq newToolBar (vla-Add (vla-get-Toolbars currMenuGroup) "TestToolbar")) ;; Add an item to the new Toolbar and assign an Open macro ;; (VBA equivalent of: "ESC ESC _open ") (setq openMacro (strcat (Chr 3) (Chr 3) (Chr 95) "open" (Chr 32))) (setq newButton (vla-AddToolbarButton newToolBar "" "NewButton" "Open a file." openMacro)) ;; Read icon paths for this Toolbar button (vla-GetBitmaps newButton 'SmallBitmapName 'LargeBitmapName) (alert (strcat "The new Toolbar uses the following icon files: \n" "Small Bitmap: " SmallBitmapName "\n" "Large Bitmap: " LargeBitmapName)) ;; Change the default icon (smile face) for the new toolbar button (setq SmallBitmapName "C:\\AutoCAD\\16x16.bmp") ;; Use a 16x16 pixel .BMP image (setq LargeBitmapName "C:\\AutoCAD\\32x32.bmp") ;; Use a 32x32 pixel .BMP image (vla-SetBitmaps newButton SmallBitmapName LargeBitmapName) ;; Read icon paths for this Toolbar button (vla-GetBitmaps newButton 'SmallBitmapName 'LargeBitmapName) (alert (strcat "The new Toolbar uses the following icon files: \n" "Small Bitmap: " SmallBitmapName "\n" "Large Bitmap: " LargeBitmapName)) ) |
GMT+8, 2024-6-2 19:32
