拭除选择集中的所有对象。 支持的平台:仅窗口 返回值(RetVal)无返回值。 言论没有额外的评论。 例子工 务 局: Sub Example_Erase() ' This example creates a selection set and several objects. ' It then adds the objects to the selection set, and then ' erases the objects from the selection set. ' Create the new selection set Dim ssetObj As AcadSelectionSet Set ssetObj = ThisDrawing.SelectionSets.Add("TEST_SELECTIONSET") ' Create a Ray object in model space Dim rayObj As AcadRay Dim basePoint(0 To 2) As Double Dim SecondPoint(0 To 2) As Double basePoint(0) = 3#: basePoint(1) = 3#: basePoint(2) = 0# SecondPoint(0) = 1#: SecondPoint(1) = 3#: SecondPoint(2) = 0# Set rayObj = ThisDrawing.ModelSpace.AddRay(basePoint, SecondPoint) ' Create a polyline object in model space Dim plineObj As AcadLWPolyline Dim points(0 To 5) As Double points(0) = 3: points(1) = 7 points(2) = 9: points(3) = 2 points(4) = 3: points(5) = 5 Set plineObj = ThisDrawing.ModelSpace.AddLightWeightPolyline(points) plineObj.Closed = True ' Create a line object in model space Dim lineObj As AcadLine Dim startPoint(0 To 2) As Double Dim endPoint(0 To 2) As Double startPoint(0) = 0: startPoint(1) = 0: startPoint(2) = 0 endPoint(0) = 2: endPoint(1) = 2: endPoint(2) = 0 Set lineObj = ThisDrawing.ModelSpace.AddLine(startPoint, endPoint) ' Create a circle object in model space Dim circObj As AcadCircle Dim centerPt(0 To 2) As Double Dim radius As Double centerPt(0) = 20: centerPt(1) = 30: centerPt(2) = 0 radius = 3 Set circObj = ThisDrawing.ModelSpace.AddCircle(centerPt, radius) ' Create an ellipse object in model space Dim ellObj As AcadEllipse Dim majAxis(0 To 2) As Double Dim center(0 To 2) As Double Dim radRatio As Double center(0) = 5#: center(1) = 5#: center(2) = 0# majAxis(0) = 10: majAxis(1) = 20#: majAxis(2) = 0# radRatio = 0.3 Set ellObj = ThisDrawing.ModelSpace.AddEllipse(center, majAxis, radRatio) ZoomAll ' Iterate through the model space collection. ' Collect the objects found into an array of objects ' to be added to the selection set. ReDim ssobjs(0 To ThisDrawing.ModelSpace.count - 1) As AcadEntity Dim I As Integer For I = 0 To ThisDrawing.ModelSpace.count - 1 Set ssobjs(I) = ThisDrawing.ModelSpace.Item(I) Next ' Add the array of objects to the selection set ssetObj.AddItems ssobjs GoSub LISTOBJS ' Erase the objects in the selection set ssetObj.Erase GoSub LISTOBJS ' exit the subroutine Exit Sub LISTOBJS: ' List all the objects in the selection set If ssetObj.count = 0 Then MsgBox "The selection set is empty" Else For I = 0 To ssetObj.count - 1 MsgBox "The selection set contains: " & ssetObj.Item(I).ObjectName Next End If Return End Sub Visual LISP: (vl-load-com) (defun c:Example_Erase() ;; This example creates a selection set and several objects. ;; It then adds the objects to the selection set, and then ;; erases the objects from the selection set. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Create the new selection set (setq ssetObj (vla-Add (vla-get-SelectionSets doc) "TEST_SELECTIONSET")) ;; Create a Ray object in model space (setq basePoint (vlax-3d-point 3 3 0) secondPoint (vlax-3d-point 1 3 0)) (setq modelSpace (vla-get-ModelSpace doc)) (setq rayObj (vla-AddRay modelSpace basePoint SecondPoint)) ;; Create a polyline object in model space (setq points (vlax-make-safearray vlax-vbDouble '(0 . 5))) (vlax-safearray-fill points '(3 7 9 2 3 5 ) ) (setq plineObj (vla-AddLightWeightPolyline modelSpace points)) (vla-put-Closed plineObj :vlax-true) ;; Create a line object in model space (setq startPoint (vlax-3d-point 0 0 0) endPoint (vlax-3d-point 2 2 0)) (setq lineObj (vla-AddLine modelSpace startPoint endPoint)) ;; Create a circle object in model space (setq centerPt (vlax-3d-point 20 30 0) radius 3) (setq circObj (vla-AddCircle modelSpace centerPt radius)) ;; Create an ellipse object in model space (setq majAxis (vlax-3d-point 5 5 0) center (vlax-3d-point 10 20 0) radRatio 0.3) (setq ellObj (vla-AddEllipse modelSpace center majAxis radRatio)) (vla-ZoomAll acadObj) ;; Iterate through the model space collection. ;; Collect the objects found into an array of objects ;; to be added to the selection set. (setq ssobjs (vlax-make-safearray vlax-vbObject (cons 0 (- (vla-get-Count modelSpace) 1)))) (setq I 0) (while (>= (- (vla-get-Count modelSpace) 1) I) (vlax-safearray-put-element ssobjs I (vla-Item modelSpace I)) (setq I (1+ I)) ) ;; Add the array of objects to the selection set (vla-AddItems ssetObj ssobjs) ;; List all the objects in the selection set (if (= (vla-get-Count ssetObj) 0) (alert "The selection set is empty") (progn (setq I 0) (while (>= (- (vla-get-Count ssetObj) 1) I) (alert (strcat "The selection set contains: " (vla-get-ObjectName (vla-Item ssetObj I)))) (setq I (1+ I)) ) ) ) ;; Erase the objects in the selection set (vla-Erase ssetObj) ;; List all the objects in the selection set (if (= (vla-get-Count ssetObj) 0) (alert "The selection set is empty") (progn (setq I 0) (while (>= (- (vla-get-Count ssetObj) 1) I) (alert (strcat "The selection set contains: " (vla-get-ObjectName (vla-Item ssetObj I)))) ) ) ) ) |
GMT+8, 2024-6-10 23:26
