创建包含类型化参数数组的变体。 支持的平台:仅窗口 签名工 务 局: object.CreateTypedArray VarArr, Type, Value1, [value2, value3, ...valueN]
返回值(RetVal)无返回值。 言论生成的变体可以传递到接受数字数组作为变体的任何 AutoCAD 方法或属性中。 此方法只能使用后期绑定编程技术访问。若要使用此方法,请将对象定义为,而不是为。UtilityObject (Dim myObj As Object)AcadUtility 例子工 务 局: Sub Example_CreateTypedArray() ' This example creates a spline from variant arrays created ' from doubles using the CreateTypedArray method. ' Note that this method must be late bound. This is done ' by declaring the utility object (utilObj) as Object, ' not as AcadUtility. Dim splineObj As AcadSpline ' Even though these are arrays, they are declared as variants Dim startTan As Variant Dim endTan As Variant Dim fitPoints As Variant Dim utilObj As Object ' Late bound object Set utilObj = ThisDrawing.Utility ' Define the spline. utilObj.CreateTypedArray startTan, vbDouble, 0.5, 0.5, 0 utilObj.CreateTypedArray endTan, vbDouble, 0.5, 0.5, 0 utilObj.CreateTypedArray fitPoints, vbDouble, 0, 0, 0, 5, 5, 0, 10, 0, 0 ' Create the spline Set splineObj = ThisDrawing.ModelSpace.AddSpline(fitPoints, startTan, endTan) ZoomAll End Sub Visual LISP: (vl-load-com) (defun c:Example_CreateTypedArray() ;; This example creates a spline from variant arrays created ;; from doubles using the CreateTypedArray method. ;; Note that this method must be late bound. This is done ;; by declaring the utility object (utilObj) as Object, ;; not as AcadUtility. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) (setq utilObj (vla-get-Utility doc)) ;; Define the spline. (vla-CreateTypedArray utilObj 'startTan vlax-vbDouble 0.5 0.5 0) (vla-CreateTypedArray utilObj 'endTan vlax-vbDouble 0.5 0.5 0) (vla-CreateTypedArray utilObj 'fitPoints vlax-vbDouble 0 0 0 5 5 0 10 0 0) ;; Create the spline (setq modelSpace (vla-get-ModelSpace doc)) (setq splineObj (vla-AddSpline modelSpace fitPoints startTan endTan)) (vla-ZoomAll acadObj) ) |
GMT+8, 2024-6-11 05:08
