复制标注样式、布局或打印配置的设置。 支持的平台:仅窗口 签名工 务 局: object.CopyFrom SourceObject 返回值(RetVal)无返回值。 言论DimStyle:此方法允许用户将标注样式数据从三种不同类型的源复制到现有标注样式中。
例子工 务 局: Sub Example_CopyFrom() ' This example will create two new plot configurations, NewPC1 and NewPC2, and will use ' the CopyFrom method to duplicate the settings in the first plot configuration ' to the second plot configuration. Dim PlotConfigurations As AcadPlotConfigurations Dim PlotConfiguration As AcadPlotConfiguration Dim NewPC1 As AcadPlotConfiguration, NewPC2 As AcadPlotConfiguration ' Get PlotConfigurations collection from document object Set PlotConfigurations = ThisDrawing.PlotConfigurations ' Add NewPC1 and customize some of the properties Set NewPC1 = PlotConfigurations.Add("NEW_CONFIGURATION1") NewPC1.PlotRotation = ac270degrees NewPC1.PlotHidden = True NewPC1.PaperUnits = acMillimeters ' Add NewPC2 and leave default values intact Set NewPC2 = PlotConfigurations.Add("NEW_CONFIGURATION2") ' Show NewPC2 settings before we copy information from NewPC1 GoSub VIEWPC2SETTINGS ' Copy setting information from NewPC1 to NewPC2 NewPC2.CopyFrom NewPC1 NewPC2.name = "NEW_CONFIGURATION2" ' Show NewPC2 settings after we copy information from NewPC1 GoSub VIEWPC2SETTINGS Exit Sub VIEWPC2SETTINGS: MsgBox "The settings for NEW_CONFIGURATION2 are: " & vbCrLf & _ "Plot Rotation: " & NewPC2.PlotRotation & vbCrLf & _ "Plot Hidden: " & NewPC2.PlotHidden & vbCrLf & _ "Paper Units: " & NewPC2.PaperUnits Return End Sub Visual LISP: (vl-load-com) (defun c:Example_CopyFrom() ;; This example will create two new plot configurations, NewPC1 and NewPC2, and will use ;; the CopyFrom method to duplicate the settings in the first plot configuration ;; to the second plot configuration. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Get PlotConfigurations collection from document object (setq PlotConfigurations (vla-get-PlotConfigurations doc)) ;; Add NewPC1 and customize some of the properties (setq NewPC1 (vla-Add PlotConfigurations "NEW_CONFIGURATION1")) (vla-put-PlotRotation NewPC1 ac270degrees) (vla-put-PlotHidden NewPC1 :vlax-true) (vla-put-PaperUnits NewPC1 acMillimeters) ;; Add NewPC2 and leave default values intact (setq NewPC2 (vla-Add PlotConfigurations "NEW_CONFIGURATION2")) ;; Show NewPC2 settings before we copy information from NewPC1 (alert (strcat "The settings for NEW_CONFIGURATION2 are: " "\nPlot Rotation: " (itoa (vla-get-PlotRotation NewPC2)) "\nPlot Hidden: " (if (= (vla-get-PlotHidden NewPC2) :vlax-true) "True" "False") "\nPaper Units: " (itoa (vla-get-PaperUnits NewPC2)) ) ) ;; Copy setting information from NewPC1 to NewPC2 (vla-CopyFrom NewPC2 NewPC1) (vla-put-Name NewPC2 "NEW_CONFIGURATION2") ;; Show NewPC2 settings after we copy information from NewPC1 (alert (strcat "The settings for NEW_CONFIGURATION2 are: " "\nPlot Rotation: " (itoa (vla-get-PlotRotation NewPC2)) "\nPlot Hidden: " (if (= (vla-get-PlotHidden NewPC2) :vlax-true) "True" "False") "\nPaper Units: " (itoa (vla-get-PaperUnits NewPC2)) ) ) ) |
GMT+8, 2024-6-2 17:42
