指定光栅图像或参考底图的剪裁边界。 支持的平台:仅窗口 签名工 务 局: object.ClipBoundary PointsArray
返回值(RetVal)无返回值。 言论您可以通过剪切对象来定义图像或参考底图对象的区域以进行显示和打印。同一对象的多个实例可以具有不同的边界。 裁剪边界必须是闭合的 2D 多边形或矩形,其顶点被约束为位于图像或参考底图的边界内。 要剪裁图像或参考底图,对象的边界必须可见。使用该属性打开或关闭剪切边界。ClippingEnabled 例子工 务 局: Sub Example_ClipBoundary() ' This example adds a raster image in model space. ' It then clips the image based on a clip boundary. ' This example uses the "2d Projected Polylines.jpg" found in the Sample ' directory. If you do not have the image, or if it is located ' in a different directory, insert a valid path and name for the ' imageName variable below. Dim insertionPoint(0 To 2) As Double Dim scalefactor As Double Dim rotationAngle As Double Dim imageName As String Dim rasterObj As AcadRasterImage imageName = "C:\AutoCAD\sample\2d Projected Polylines.jpg" insertionPoint(0) = 5#: insertionPoint(1) = 5#: insertionPoint(2) = 0# scalefactor = 2# rotationAngle = 0 On Error Resume Next ' Creates a raster image in model space Set rasterObj = ThisDrawing.ModelSpace.AddRaster(imageName, insertionPoint, scalefactor, rotationAngle) If Err.Description = "Filer error" Then MsgBox imageName & " could not be found." Exit Sub End If ZoomAll MsgBox "Clip the image?", , "ClipBoundary Example" ' Establish the clip boundary with an array of points Dim clipPoints(0 To 9) As Double clipPoints(0) = 6: clipPoints(1) = 6.75 clipPoints(2) = 7: clipPoints(3) = 6 clipPoints(4) = 6: clipPoints(5) = 5 clipPoints(6) = 5: clipPoints(7) = 6 clipPoints(8) = 6: clipPoints(9) = 6.75 ' Clip the image rasterObj.clipBoundary clipPoints ' Enable the display of the clip rasterObj.ClippingEnabled = True ThisDrawing.Regen acActiveViewport MsgBox "The image has been clipped.", , "ClipBoundary Example" End Sub Visual LISP: (vl-load-com) (defun c:Example_ClipBoundary() ;; This example adds a raster image in model space. ;; It then clips the image based on a clip boundary. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; This example uses the "2d Projected Polylines.jpg" found in the Sample ;; directory. If you do not have the image, or if it is located ;; in a different directory, insert a valid path and name for the ;; imageName variable below. (setq insertionPoint (vlax-3d-point 5 5 0) imageName ".\\Sample\\VBA\\2d Projected Polylines.jpg" scalefactor 2 rotationAngle 0) (if (/= (findfile ".\\Sample\\VBA\\2d Projected Polylines.jpg") nil) (progn ;; Creates a raster image in model space (setq modelSpace (vla-get-ModelSpace doc)) (setq rasterObj (vla-AddRaster modelSpace (findfile ".\\Sample\\VBA\\2d Projected Polylines.jpg") insertionPoint scalefactor rotationAngle)) (vla-ZoomAll acadObj) (alert "Clip the image?") ;; Establish the clip boundary with an array of points (setq clipPoints (vlax-make-safearray vlax-vbDouble '(0 . 9))) (vlax-safearray-fill clipPoints '(6 6.75 7 6 6 5 5 6 6 6.75 ) ) ;; Clip the image (vla-ClipBoundary rasterObj clipPoints) ;; Enable the display of the clip (vla-put-ClippingEnabled rasterObj :vlax-true) (vla-Regen doc acActiveViewport) (alert "The image has been clipped.") ) (alert (strcat imageName " could not be found.")) ) ) |
GMT+8, 2024-6-10 18:42
