将外部环追加到填充。 支持的平台:仅窗口 签名工 务 局: object.AppendOuterLoop loop 返回值(RetVal)无返回值。 言论使用该方法创建对象后,添加外部循环。必须关闭外部循环,并且必须先创建外部循环,然后才能添加任何内部循环。创建有效的外部循环后,使用 the方法 添加任何内部循环,一次添加一个。HatchAddHatchAppendInnerLoop 定义完图案填充的边界后,使用该方法计算图案填充线或填充边界,然后使用该方法更新图案填充的显示。EvaluateRegen 例子工 务 局: Sub Example_AppendOuterLoop() ' This example creates an associative hatch in model space, and then creates an outer loop for the hatch. Dim hatchObj As AcadHatch Dim patternName As String Dim PatternType As Long Dim bAssociativity As Boolean ' Define the hatch patternName = "ANSI31" PatternType = 0 bAssociativity = True ' Create the associative Hatch object Set hatchObj = ThisDrawing.ModelSpace.AddHatch(PatternType, patternName, bAssociativity) ' Create the outer loop for the hatch. ' An arc and a line are used to create a closed loop. Dim outerLoop(0 To 1) As AcadEntity Dim center(0 To 2) As Double Dim radius As Double Dim startAngle As Double Dim endAngle As Double center(0) = 5: center(1) = 3: center(2) = 0 radius = 1 startAngle = 0 endAngle = 3.141592 Set outerLoop(0) = ThisDrawing.ModelSpace.AddArc(center, radius, startAngle, endAngle) Set outerLoop(1) = ThisDrawing.ModelSpace.AddLine(outerLoop(0).startPoint, outerLoop(0).endPoint) ' Append the outer loop to the hatch object, and display the hatch hatchObj.AppendOuterLoop (outerLoop) hatchObj.Evaluate ZoomAll End Sub Visual LISP: (vl-load-com) (defun c:Example_AppendOuterLoop() ;; This example creates an associative hatch in model space, and ;; then creates an outer loop for the hatch. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Define the hatch (setq patternName "ANSI31" patternType 0 bAssociativity :vlax-true) ;; Create the associative Hatch object (setq modelSpace (vla-get-ModelSpace doc)) (setq hatchObj (vla-AddHatch modelSpace patternType patternName bAssociativity acHatchObject)) ;; Create the outer loop for the hatch. ;; An arc and a line are used to create a closed loop. (setq center (vlax-3d-point 5 3 0) radius 3 startAngle 0 endAngle 3.141592) (setq arc (vla-AddArc modelSpace center radius startAngle endAngle)) (setq line (vla-AddLine modelSpace (vla-get-StartPoint arc) (vla-get-EndPoint arc))) (setq outerLoop (vlax-make-safearray vlax-vbObject '(0 . 1))) (vlax-safearray-put-element outerLoop 0 arc) (vlax-safearray-put-element outerLoop 1 line) ;; Append the outer loop to the hatch object, and display the hatch (vla-AppendOuterLoop hatchObj outerLoop) (vla-Evaluate hatchObj) (vla-ZoomAll acadObj) ) |
GMT+8, 2024-6-2 18:00
