将一个或多个实体追加到指定的组。 支持的平台:仅窗口 签名工 务 局: object.AppendItems Objects 返回值(RetVal)无返回值。 言论若要查询组中的项目,请使用该方法。Item 若要从组中删除单个项目,请使用该方法。RemoveItems 例子工 务 局: Sub Example_AppendItems() ' This example creates a group and several objects. ' It then appends the objects to the group. ' Create the new group Dim groupObj As AcadGroup Set groupObj = ThisDrawing.Groups.Add("TEST_GROUP") ' Create a Ray object in model space Dim rayObj As AcadRay Dim basePoint(0 To 2) As Double Dim SecondPoint(0 To 2) As Double basePoint(0) = 3#: basePoint(1) = 3#: basePoint(2) = 0# SecondPoint(0) = 1#: SecondPoint(1) = 3#: SecondPoint(2) = 0# Set rayObj = ThisDrawing.ModelSpace.AddRay(basePoint, SecondPoint) ' Create a polyline object in model space Dim plineObj As AcadLWPolyline Dim points(0 To 5) As Double points(0) = 3: points(1) = 7 points(2) = 9: points(3) = 2 points(4) = 3: points(5) = 5 Set plineObj = ThisDrawing.ModelSpace.AddLightWeightPolyline(points) plineObj.Closed = True ' Create a line object in model space Dim lineObj As AcadLine Dim startPoint(0 To 2) As Double Dim endPoint(0 To 2) As Double startPoint(0) = 0: startPoint(1) = 0: startPoint(2) = 0 endPoint(0) = 2: endPoint(1) = 2: endPoint(2) = 0 Set lineObj = ThisDrawing.ModelSpace.AddLine(startPoint, endPoint) ' Create a circle object in model space Dim circObj As AcadCircle Dim centerPt(0 To 2) As Double Dim radius As Double centerPt(0) = 20: centerPt(1) = 30: centerPt(2) = 0 radius = 3 Set circObj = ThisDrawing.ModelSpace.AddCircle(centerPt, radius) ' Create an ellipse object in model space Dim ellObj As AcadEllipse Dim majAxis(0 To 2) As Double Dim center(0 To 2) As Double Dim radRatio As Double center(0) = 5#: center(1) = 5#: center(2) = 0# majAxis(0) = 10: majAxis(1) = 20#: majAxis(2) = 0# radRatio = 0.3 Set ellObj = ThisDrawing.ModelSpace.AddEllipse(center, majAxis, radRatio) ZoomAll ' Iterate through the model space collection. ' Collect the objects found into an array of objects ' to be added to the group. ReDim appendObjs(0 To ThisDrawing.ModelSpace.count - 1) As AcadEntity Dim I As Integer For I = 0 To ThisDrawing.ModelSpace.count - 1 Set appendObjs(I) = ThisDrawing.ModelSpace.Item(I) Next ' Add the array of objects to the group groupObj.AppendItems appendObjs ThisDrawing.Regen acActiveViewport End Sub Visual LISP: (vl-load-com) (defun c:Example_AppendItems() ;; This example creates a group and several objects. ;; It then appends the objects to the group. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Create the new group (setq groupObj (vla-Add (vla-get-Groups doc) "TEST_GROUP")) ;; Create a Ray object in model space (setq basePoint (vlax-3d-point 3 3 0) secondPoint (vlax-3d-point 1 3 0)) (setq modelSpace (vla-get-ModelSpace doc)) (setq rayObj (vla-AddRay modelSpace basePoint SecondPoint)) ;; Create a polyline object in model space (setq points (vlax-make-safearray vlax-vbDouble '(0 . 5))) (vlax-safearray-fill points '(3 7 9 2 3 5 ) ) (setq plineObj (vla-AddLightWeightPolyline modelSpace points)) (vla-put-Closed plineObj :vlax-true) ;; Create a line object in model space (setq startPoint (vlax-3d-point 0 0 0) endPoint (vlax-3d-point 2 2 0)) (setq lineObj (vla-AddLine modelSpace startPoint endPoint)) ;; Create a circle object in model space (setq centerPt (vlax-3d-point 20 30 0) radius 3) (setq circObj (vla-AddCircle modelSpace centerPt radius)) ;; Create an ellipse object in model space (setq center (vlax-3d-point 5 5 0) majAxis (vlax-3d-point 10 20 0) radRatio 0.3) (setq ellObj (vla-AddEllipse modelSpace center majAxis radRatio)) (vla-ZoomAll acadObj) ;; Iterate through the model space collection. ;; Collect the objects found into an array of objects ;; to be added to the group. (setq I 0 totalObjs (vla-get-Count modelSpace)) (setq appendObjs (vlax-make-safearray vlax-vbObject (cons 0 (- totalObjs 1)))) (while (>= (- totalObjs 1) I) (vlax-safearray-put-element appendObjs I (vla-Item modelSpace I)) (setq I (1+ I)) ) ;; Add the array of objects to the group (vla-AppendItems groupObj appendObjs) (vla-Regen doc acActiveViewport) ) |
GMT+8, 2024-6-11 03:08
