获取线条与 X 轴的角度。 支持的平台:仅窗口 签名工 务 局: RetVal = AngleFromXAxis(Point1, Point2)
返回值(RetVal)类型:双 线的角度(以弧度为单位)。 言论没有额外的评论。 例子工 务 局: Sub Example_AngleFromXAxis() ' This example finds the angle, in radians, between the X axis ' and a line defined by two points. Dim pt1(0 To 2) As Double Dim pt2(0 To 2) As Double Dim retAngle As Double pt1(0) = 2: pt1(1) = 5: pt1(2) = 0 pt2(0) = 5: pt2(1) = 2: pt2(2) = 0 ' Return the angle retAngle = ThisDrawing.Utility.AngleFromXAxis(pt1, pt2) ' Create the line for a visual reference Dim lineObj As AcadLine Set lineObj = ThisDrawing.ModelSpace.AddLine(pt1, pt2) ZoomAll ' Display the angle found MsgBox "The angle in radians between the X axis and the line is " & retAngle, , "AngleFromXAxis Example" End Sub Visual LISP: (vl-load-com) (defun c:Example_AngleFromXAxis() ;; This example finds the angle, in radians, between the X axis ;; and a line defined by two points. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Return the angle (setq pt1 (vlax-3d-point 2 5 0) pt2 (vlax-3d-point 5 2 0)) (setq retAngle (vla-AngleFromXAxis (vla-get-Utility doc) pt1 pt2)) ;; Create the line for a visual reference (setq modelSpace (vla-get-ModelSpace doc)) (setq lineObj (vla-AddLine modelSpace pt1 pt2)) (vla-ZoomAll acadObj) ;; Display the angle found (alert (strcat "The angle in radians between the X axis and the line is " (rtos retAngle 2))) ) |
GMT+8, 2024-6-11 00:00
