创建单行文本。 支持的平台:仅窗口 签名工 务 局: RetVal = object.AddText(TextString, InsertionPoint, Height) 言论没有额外的评论。 例子工 务 局: Sub Example_AddText() ' This example creates a text object in model space. Dim textObj As AcadText Dim textString As String Dim insertionPoint(0 To 2) As Double Dim height As Double ' Define the text object textString = "Hello, World." insertionPoint(0) = 2: insertionPoint(1) = 2: insertionPoint(2) = 0 height = 0.5 ' Create the text object in model space Set textObj = ThisDrawing.ModelSpace.AddText(textString, insertionPoint, height) ZoomAll End Sub Visual LISP: (vl-load-com) (defun c:Example_AddText() ;; This example creates a text object in model space. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Define the text object (setq insertionPoint (vlax-3d-point 2 2 0) textString "Hello, World." height 0.5) ;; Create the text object in model space (setq modelSpace (vla-get-ModelSpace doc)) (setq textObj (vla-AddText modelSpace textString insertionPoint height)) (vla-ZoomAll acadObj) ) |
GMT+8, 2024-6-10 16:29
