创建一个给定中心和半径的球体。 支持的平台:仅窗口 签名工 务 局: RetVal = object.AddSphere(Center, Radius) 言论没有额外的评论。 例子工 务 局: Sub Example_AddSphere() ' This example creates a sphere in model space. Dim sphereObj As Acad3DSolid Dim centerPoint(0 To 2) As Double Dim radius As Double centerPoint(0) = 5#: centerPoint(1) = 5#: centerPoint(2) = 0# radius = 5# Set sphereObj = ThisDrawing.ModelSpace.AddSphere(centerPoint, radius) ' Change the viewing direction of the viewport Dim NewDirection(0 To 2) As Double NewDirection(0) = -1: NewDirection(1) = -1: NewDirection(2) = 1 ThisDrawing.ActiveViewport.direction = NewDirection ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport ZoomAll End Sub Visual LISP: (vl-load-com) (defun c:Example_AddSphere() ;; This example creates a sphere in model space. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Define the solid sphere (setq centerPoint (vlax-3d-point 5 5 0) radius 5) (setq modelSpace (vla-get-ModelSpace doc)) (setq sphereObj (vla-AddSphere modelSpace centerPoint radius)) ;; Change the viewing direction of the viewport (setq NewDirection (vlax-3d-point -1 -1 1)) (setq activeViewport (vla-get-ActiveViewport doc)) (vla-put-Direction activeViewport NewDirection) (vla-put-ActiveViewport doc activeViewport) (vla-ZoomAll acadObj) ) |
GMT+8, 2024-6-2 18:49
