从顶点列表创建折线。 支持的平台:仅窗口 签名工 务 局: RetVal = object.AddPolyline(VerticesList) 言论要创建包含圆弧的折线,请先创建直线折线,然后使用该方法在特定顶点处设置凸起。SetBulge 此方法的存在只是为了向后兼容。使用该方法创建具有优化格式的折线,以节省内存和磁盘空间。AddLightweightPolyline 可以使用该方法将坐标与OCS相互转换。TranslateCoordinates 例子工 务 局: Sub Example_AddPolyline() ' This example creates a polyline in model space. Dim plineObj As AcadPolyline Dim points(0 To 14) As Double ' Define the 2D polyline points points(0) = 1: points(1) = 1: points(2) = 0 points(3) = 1: points(4) = 2: points(5) = 0 points(6) = 2: points(7) = 2: points(8) = 0 points(9) = 3: points(10) = 2: points(11) = 0 points(12) = 4: points(13) = 4: points(14) = 0 ' Create a lightweight Polyline object in model space Set plineObj = ThisDrawing.ModelSpace.AddPolyline(points) ZoomAll End Sub Visual LISP: (vl-load-com) (defun c:Example_AddPolyline() ;; This example creates a polyline in model space. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Define the 2D polyline points (setq points (vlax-make-safearray vlax-vbDouble '(0 . 14))) (vlax-safearray-fill points '(1 1 0 1 2 0 2 2 0 3 2 0 4 4 0 ) ) ;; Create a lightweight Polyline object in model space (setq modelSpace (vla-get-ModelSpace doc)) (setq plineObj (vla-AddPolyline modelSpace points)) (vla-ZoomAll acadObj) ) |
GMT+8, 2024-6-10 18:39
