在给定轮廓和拉伸路径的情况下创建拉伸实体。 支持的平台:仅窗口 签名工 务 局: RetVal = object.AddExtrudedSolidAlongPath(Profile, Path) 言论只能拉伸 2D 平面区域。 路径不应与轮廓位于同一平面上,也不应具有高曲率区域。 例子工 务 局: Sub Example_AddExtrudedSolidAlongPath() ' This example extrudes a solid from a region ' along a path defined by a spline. ' The region is created from an arc and a line. Dim curves(0 To 1) As AcadEntity ' Define the arc Dim centerPoint(0 To 2) As Double Dim radius As Double Dim startAngle As Double Dim endAngle As Double centerPoint(0) = 5#: centerPoint(1) = 3#: centerPoint(2) = 0# radius = 2# startAngle = 0 endAngle = 3.141592 Set curves(0) = ThisDrawing.ModelSpace.AddArc(centerPoint, radius, startAngle, endAngle) ' Define the line Set curves(1) = ThisDrawing.ModelSpace.AddLine(curves(0).startPoint, curves(0).endPoint) ' Create the region Dim regionObj As Variant regionObj = ThisDrawing.ModelSpace.AddRegion(curves) ' Define the extrusion path (spline object) Dim splineObj As AcadSpline Dim startTan(0 To 2) As Double Dim endTan(0 To 2) As Double Dim fitPoints(0 To 8) As Double ' Define the Spline Object startTan(0) = 10: startTan(1) = 10: startTan(2) = 10 endTan(0) = 10: endTan(1) = 10: endTan(2) = 10 fitPoints(0) = 0: fitPoints(1) = 10: fitPoints(2) = 10 fitPoints(0) = 10: fitPoints(1) = 10: fitPoints(2) = 10 fitPoints(0) = 15: fitPoints(1) = 10: fitPoints(2) = 10 Set splineObj = ThisDrawing.ModelSpace.AddSpline(fitPoints, startTan, endTan) ' Create the solid Dim solidObj As Acad3DSolid Set solidObj = ThisDrawing.ModelSpace.AddExtrudedSolidAlongPath(regionObj(0), splineObj) ZoomAll End Sub Visual LISP: (vl-load-com) (defun c:Example_AddExtrudedSolidAlongPath() ;; This example extrudes a solid from a region ;; along a path defined by a spline. ;; The region is created from an arc and a line. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) (setq modelSpace (vla-get-ModelSpace doc)) ;; Define the arc (setq centerPoint (vlax-3d-point 5 3 0) radius 2 startAngle 0 endAngle 3.141592) (setq arc (vla-AddArc modelSpace centerPoint radius startAngle endAngle)) ;; Define the line (setq line (vla-AddLine modelSpace (vla-get-StartPoint arc) (vla-get-EndPoint arc))) (setq curves (vlax-make-safearray vlax-vbObject '(0 . 1))) (vlax-safearray-put-element curves 0 arc) (vlax-safearray-put-element curves 1 line) ;; Create the region ;(setq regionObj (vlax-make-safearray vlax-vbObject '(0 . 0))) (setq regionObj (vla-AddRegion modelSpace curves)) ;; Define the extrusion path (spline object) (setq startTan (vlax-3d-point 10 10 10) endTan (vlax-3d-point 10 10 10)) (setq fitPoints (vlax-make-safearray vlax-vbDouble '(0 . 8))) (vlax-safearray-fill fitPoints '(0 10 10 10 10 10 15 10 10 ) ) (setq splineObj (vla-AddSpline modelSpace fitPoints startTan endTan)) ;; Create the solid (setq solidObj (vla-AddExtrudedSolidAlongPath modelSpace (vlax-safearray-get-element (vlax-variant-value regionObj) 0) splineObj)) (vla-ZoomAll acadObj) ) |
GMT+8, 2024-6-10 18:28
