创建一个三维实体椭圆圆柱体,其底部位于 WCS 的 XY 平面上,给定中心、大半径、小半径和高度。 支持的平台:仅窗口 签名工 务 局: RetVal = object.AddEllipticalCylinder(Center, MajorRadius, MinorRadius, Height) 言论没有额外的评论。 例子工 务 局: Sub Example_AddEllipticalCylinder() ' This example creates an elliptical cylinder in model space. Dim cylinderObj As Acad3DSolid Dim center(0 To 2) As Double Dim majorRadius As Double Dim minorRadius As Double Dim height As Double ' Define the elliptical cylinder center(0) = 0#: center(1) = 0#: center(2) = 0# majorRadius = 5# minorRadius = 2.5 height = 10# ' Create the elliptical cylinder in model space Set cylinderObj = ThisDrawing.ModelSpace.AddEllipticalCylinder(center, majorRadius, minorRadius, height) ' Change the viewing direction of the viewport to better see the cylinder Dim NewDirection(0 To 2) As Double NewDirection(0) = -1: NewDirection(1) = -1: NewDirection(2) = 1 ThisDrawing.ActiveViewport.direction = NewDirection ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport ZoomAll End Sub Visual LISP: (vl-load-com) (defun c:Example_AddEllipticalCylinder() ;; This example creates an elliptical cylinder in model space. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Define the elliptical cylinder (setq center (vlax-3d-point 0 0 0) majorRadius 5 minorRadius 2.5 height 10) ;; Create the elliptical cylinder in model space (setq modelSpace (vla-get-ModelSpace doc)) (setq cylinderObj (vla-AddEllipticalCylinder modelSpace center majorRadius minorRadius height)) ;; Change the viewing direction of the viewport to better see the cylinder (setq NewDirection (vlax-3d-point -1 -1 1)) (setq activeViewport (vla-get-ActiveViewport doc)) (vla-put-Direction activeViewport NewDirection) (vla-put-ActiveViewport doc activeViewport) (vla-ZoomAll acadObj) ) |
GMT+8, 2024-6-11 00:00
