创建一个成员对象并将其添加到相应的集合中。 支持的平台:仅窗口 签名 - 块工 务 局: RetVal = object.Add(InsertionPoint, Name)
签名 - UCS工 务 局: RetVal = object.Add(Origin, XAxisPoint, YAxisPoint, Name)
签名 - 超链接工 务 局: RetVal = object.Add(Name [, Description] [, NamedLocation])
Signature - PlotConfigurationsVBA: RetVal = object.Add(Name [, ModelType])
Signature - All other supported objectsVBA: RetVal = object.Add(Name)
Return Value (RetVal)Type: Block, Dictionary, DimStyle, Document, Group, Hyperlink, Layer, Layout, Linetype, Material, PlotConfiguration, PopupMenu, RegisteredApplication, SelectionSet, TextStyle, Toolbar, UCS, View, Viewport The newly added object. RemarksAlthough you can create a linetype and add it to the object using this method, it will be created with the default properties only. Because you cannot edit properties of the object with this release of ActiveX Automation, use the Load method to load existing linetypes into your drawing. LinetypesLinetype Layers are created with default color and linetype properties. The default color is white, and the default linetype is standard. Documents: When accessing a secure URL, a dialog box will be posted that prompts the user for the necessary password information. Message boxes may also be displayed if the user has not suppressed this activity in the browser. When downloading a file, AutoCAD creates a temporary file for internal processing. Do not attempt to access this temporary file. Information in this file is deleted at the end of the AutoCAD session. Group: You should not specify a Name that is excessively long or contains spaces, because these names are not handled well in the Group dialog box and cannot be entered at the command line. ExamplesVBA: Sub Example_Add() ' This example adds a block, dictionary, dimension style, ' group, layer, registered application, selection set, ' textstyle, view, viewport and UCS using the Add method. GoSub ADDBLOCK GoSub ADDDICTIONARY GoSub ADDDIMSTYLE GoSub ADDGROUP GoSub ADDLAYER GoSub ADDREGISTEREDAPP GoSub ADDSELECTIONSET GoSub ADDTEXTSTYLE GoSub ADDVIEW GoSub ADDVIEWPORT GoSub ADDUCS GoSub ADDMATERIAL Exit Sub ADDBLOCK: ' Create a new block called "New_Block" Dim blockObj As AcadBlock ' Define the block Dim insertionPnt(0 To 2) As Double insertionPnt(0) = 0#: insertionPnt(1) = 0#: insertionPnt(2) = 0# ' Add the block to the blocks collection Set blockObj = ThisDrawing.Blocks.Add(insertionPnt, "New_Block") MsgBox blockObj.name & " has been added." & vbCrLf & _ "Origin: " & blockObj.origin(0) & ", " & blockObj.origin(1) _ & ", " & blockObj.origin(2), , "Add Example" Return ADDDICTIONARY: ' Create a new dictionary called "New_Dictionary" Dim dictObj As AcadDictionary ' Add the dictionary to the dictionaries collection Set dictObj = ThisDrawing.Dictionaries.Add("New_Dictionary") MsgBox dictObj.name & " has been added.", , "Add Example" Return ADDDIMSTYLE: ' Create a new dimension style called "New_Dimstyle" in current drawing Dim DimStyleObj As AcadDimStyle ' Add the dimstyle to the dimstyles collection Set DimStyleObj = ThisDrawing.DimStyles.Add("New_Dimstyle") MsgBox DimStyleObj.name & " has been added.", , "Add Example" Return ADDGROUP: ' Create a new group called "New_Group" in current drawing Dim groupObj As AcadGroup ' Add the group to the groups collection Set groupObj = ThisDrawing.Groups.Add("New_Group") MsgBox groupObj.name & " has been added.", , "Add Example" Return ADDLAYER: ' This example creates a new layer called "New_Layer" Dim layerObj As AcadLayer ' Add the layer to the layers collection Set layerObj = ThisDrawing.Layers.Add("New_Layer") ' Make the new layer the active layer for the drawing ThisDrawing.ActiveLayer = layerObj ' Display the status of the new layer MsgBox layerObj.name & " has been added." & vbCrLf & _ "LayerOn Status: " & layerObj.LayerOn & vbCrLf & _ "Freeze Status: " & layerObj.Freeze & vbCrLf & _ "Lock Status: " & layerObj.Lock & vbCrLf & _ "Color: " & layerObj.Color, , "Add Example" Return ADDREGISTEREDAPP: ' Create a registered application named "New_RegApp" in current drawing Dim RegAppObj As AcadRegisteredApplication ' Add the registered application to the registered applications collection Set RegAppObj = ThisDrawing.RegisteredApplications.Add("New_RegApp") MsgBox RegAppObj.name & " has been added.", , "Add Example" Return ADDSELECTIONSET: ' Create a selectionset named "New_SelectionSet" in current drawing Dim ssetObj As AcadSelectionSet ' Add the selection set to the selection sets collection Set ssetObj = ThisDrawing.SelectionSets.Add("New_SelectionSet") MsgBox ssetObj.name & " has been added." & vbCrLf & _ "The number of items in the selection set is " & ssetObj.count _ , , "Add Example" Return ADDTEXTSTYLE: ' Create a textstyle named "New_Textstyle" in current drawing Dim txtStyleObj As AcadTextStyle ' Add the textstyle to the textstyles collection Set txtStyleObj = ThisDrawing.TextStyles.Add("New_Textstyle") MsgBox txtStyleObj.name & " has been added." & vbCrLf & _ "Height: " & txtStyleObj.height & vbCrLf & _ "Width: " & txtStyleObj.width, , "Add Example" Return ADDVIEW: ' Create a view named "New_View" in current drawing Dim viewObj As AcadView ' Add the view to the views collection Set viewObj = ThisDrawing.Views.Add("New_View") MsgBox viewObj.name & " has been added." & vbCrLf & _ "Height: " & viewObj.height & vbCrLf & _ "Width: " & viewObj.width, , "Add Example" Return ADDVIEWPORT: ' Create a viewport named "New_Viewport" in current drawing Dim vportObj As AcadViewport ' Add the viewport to the viewports collection Set vportObj = ThisDrawing.Viewports.Add("New_Viewport") MsgBox vportObj.name & " has been added." & vbCrLf & _ "GridOn Status: " & vportObj.GridOn & vbCrLf & _ "OrthoOn Status: " & vportObj.OrthoOn & vbCrLf & _ "SnapOn Status: " & vportObj.SnapOn, , "Add Example" Return ADDUCS: ' Create a UCS named "New_UCS" in current drawing Dim ucsObj As AcadUCS Dim origin(0 To 2) As Double Dim xAxisPnt(0 To 2) As Double Dim yAxisPnt(0 To 2) As Double ' Define the UCS origin(0) = 4#: origin(1) = 5#: origin(2) = 3# xAxisPnt(0) = 5#: xAxisPnt(1) = 5#: xAxisPnt(2) = 3# yAxisPnt(0) = 4#: yAxisPnt(1) = 6#: yAxisPnt(2) = 3# ' Add the UCS to the UserCoordinatesSystems collection Set ucsObj = ThisDrawing.UserCoordinateSystems.Add(origin, xAxisPnt, yAxisPnt, "New_UCS") MsgBox ucsObj.name & " has been added." & vbCrLf & _ "Origin: " & ucsObj.origin(0) & ", " & ucsObj.origin(1) _ & ", " & ucsObj.origin(2), , "Add Example" Return ADDMATERIAL: Dim oMaterial As AcadMaterial Dim oMaterials As AcadMaterials Set oMaterial = ThisDrawing.Materials.Add("TestMaterial") oMaterial.Description = "This example demonstrates how to add a material to a database." ThisDrawing.ActiveMaterial = oMaterial ' Display the status of the new layer MsgBox oMaterial.Name & " has been added." & vbCrLf & _ "Name: " & oMaterial.Name & vbCrLf & vbCrLf & _ "Description: " & vbCrLf & vbCrLf & _ oMaterial.Description Return End Sub Visual LISP: (vl-load-com) (defun c:Example_Add() ;; This example adds a block, dictionary, dimension style, ;; group, layer, registered application, selection set, ;; textstyle, view, viewport and UCS using the Add method. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; ADDBLOCK: ;; Create a new block called "New_Block" ;; Define the insertion point (setq insertionPnt (vlax-3d-point 0 0 0)) ;; Add the block to the blocks collection (setq blocks (vla-get-Blocks doc)) (setq blockObj (vla-Add blocks insertionPnt "New_Block")) (alert (strcat (vla-get-Name blockObj) " has been added." "\nOrigin: " (rtos (vlax-safearray-get-element (vlax-variant-value (vla-get-Origin blockObj)) 0) 2 2) ", " (rtos (vlax-safearray-get-element (vlax-variant-value (vla-get-Origin blockObj)) 1) 2 2) ", " (rtos (vlax-safearray-get-element (vlax-variant-value (vla-get-Origin blockObj)) 2) 2 2) ) ) ;; ADDDICTIONARY: ;; Create a new dictionary called "New_Dictionary" ;; Add the dictionary to the dictionaries collection (setq dictionaries (vla-get-Dictionaries doc)) (setq dictObj (vla-Add dictionaries "New_Dictionary")) (alert (strcat (vla-get-Name dictObj) " has been added.")) ;; ADDDIMSTYLE: ;; Create a new dimension style called "New_Dimstyle" in current drawing ;; Add the dimstyle to the dimstyles collection (setq dimStyles (vla-get-DimStyles doc)) (setq dimStyleObj (vla-Add dimStyles "New_Dimstyle")) (alert (strcat (vla-get-Name dimStyleObj) " has been added.")) ;; ADDGROUP: ;; Create a new group called "New_Group" in current drawing ;; Add the group to the groups collection (setq groups (vla-get-Groups doc)) (setq groupObj (vla-Add dimStyles "New_Group")) (alert (strcat (vla-get-Name groupObj) " has been added.")) ;; ADDLAYER: ;; This example creates a new layer called "New_Layer" ;; Add the layer to the layers collection (setq layers (vla-get-Layers doc)) (setq layerObj (vla-Add layers "New_Layer")) ;; Make the new layer the active layer for the drawing (vla-put-ActiveLayer doc layerObj) ;; Display the status of the new layer (alert (strcat (vla-get-Name layerObj) " has been added." "\nLayerOn Status: " (if (= (vla-get-LayerOn layerObj) :vlax-true) "1" "0") "\nFreeze Status: " (if (= (vla-get-Freeze layerObj) :vlax-true) "1" "0") "\nLock Status: " (if (= (vla-get-Lock layerObj) :vlax-true) "1" "0") "\nColor: " (itoa (vla-get-Color layerObj)) ) ) ;; ADDREGISTEREDAPP: ;; Create a registered application named "New_RegApp" in current drawing ;; Add the registered application to the registered applications collection (setq regApps (vla-get-RegisteredApplications doc)) (setq regAppObj (vla-Add regApps "New_RegApp")) (alert (strcat (vla-get-Name regAppObj) " has been added.")) ;; ADDSELECTIONSET: ;; Create a selectionset named "New_SelectionSet" in current drawing ;; Add the selection set to the selection sets collection (setq ssets (vla-get-SelectionSets doc)) (setq ssetObj (vla-Add ssets "New_SelectionSet")) (alert (strcat (vla-get-Name ssetObj) " has been added." "\nThe number of items in the selection set is " (itoa (vla-get-Count ssetObj)) ) ) ;; ADDTEXTSTYLE: ;; Create a textstyle named "New_Textstyle" in current drawing ;; Add the textstyle to the textstyles collection (setq textStyles (vla-get-TextStyles doc)) (setq txtStyleObj (vla-Add textStyles "New_Textstyle")) (alert (strcat (vla-get-Name txtStyleObj) " has been added." "\nHeight: " (rtos (vla-get-Height txtStyleObj) 2 2) "\nWidth: " (rtos (vla-get-Width txtStyleObj) 2 2) ) ) ;; ADDVIEW: ;; Create a view named "New_View" in current drawing ;; Add the view to the views collection (setq views (vla-get-Views doc)) (setq viewObj (vla-Add views "New_View")) (alert (strcat (vla-get-Name viewObj) " has been added." "\nHeight: " (rtos (vla-get-Height viewObj) 2 2) "\nWidth: " (rtos (vla-get-Width viewObj) 2 2) ) ) ;; ADDVIEWPORT: ;; Create a viewport named "New_Viewport" in current drawing ;; Add the viewport to the viewports collection (setq viewports (vla-get-Viewports doc)) (setq vportObj (vla-Add viewports "New_Viewport")) (alert (strcat (vla-get-Name vportObj) " has been added." "\nGridOn Status: " (if (= (vla-get-GridOn vportObj) :vlax-true) "1" "0") "\nOrthoOn Status: " (if (= (vla-get-OrthoOn vportObj) :vlax-true) "1" "0") "\nSnapOn Status: " (if (= (vla-get-SnapOn vportObj) :vlax-true) "1" "0") ) ) ;; ADDUCS: ;; Create a UCS named "New_UCS" in current drawing ;; Define the UCS (setq origin (vlax-3d-point 4 5 3) xAxisPnt (vlax-3d-point 5 5 3) yAxisPnt (vlax-3d-point 4 6 4)) ;; Add the UCS to the UserCoordinatesSystems collection (setq UCSs (vla-get-UserCoordinateSystems doc)) (setq ucsObj (vla-Add UCSs origin xAxisPnt yAxisPnt "New_UCS")) (alert (strcat (vla-get-Name ucsObj) " has been added." "\nOrigin: " (rtos (vlax-safearray-get-element (vlax-variant-value (vla-get-Origin ucsObj)) 0) 2 2) ", " (rtos (vlax-safearray-get-element (vlax-variant-value (vla-get-Origin ucsObj)) 1) 2 2) ", " (rtos (vlax-safearray-get-element (vlax-variant-value (vla-get-Origin ucsObj)) 2) 2 2) ) ) ;; ADDMATERIAL: ;; Creates a material named "New_UCS" in the current drawing (setq oMaterials (vla-get-Materials doc)) (setq oMaterial (vla-Add oMaterials "TestMaterial")) (vla-put-Description oMaterial "This example demonstrates how to add a material to a database.") (vla-put-ActiveMaterial doc oMaterial) ;; Display information about the material (alert (strcat (vla-get-Name oMaterial) " has been added." "\nName: " (vla-get-Name oMaterial) "\nDescription: " (vla-get-Description oMaterial) ) ) ) |
GMT+8, 2024-6-10 16:58
