使用该方法,可以沿由三个点指定的指定镜像平面镜像对象。Mirror3D 3D 镜像本示例在模型空间中创建一个框。然后,它会围绕平面镜像框,并将镜像框着色为红色。 Sub Ch8_MirrorABox3D() ' Create the box object Dim boxObj As Acad3DSolid Dim length As Double Dim width As Double Dim height As Double Dim center(0 To 2) As Double center(0) = 5#: center(1) = 5#: center(2) = 0 length = 5#: width = 7: height = 10# ' Create the box (3DSolid) object in model space Set boxObj = ThisDrawing.ModelSpace. _ AddBox(center, length, width, height) ' Define the mirroring plane with three points Dim mirrorPt1(0 To 2) As Double Dim mirrorPt2(0 To 2) As Double Dim mirrorPt3(0 To 2) As Double mirrorPt1(0) = 1.25: mirrorPt1(1) = 0: mirrorPt1(2) = 0 mirrorPt2(0) = 1.25: mirrorPt2(1) = 2: mirrorPt2(2) = 0 mirrorPt3(0) = 1.25: mirrorPt3(1) = 2: mirrorPt3(2) = 2 ' Mirror the box Dim mirrorBoxObj As Acad3DSolid Set mirrorBoxObj = boxObj.Mirror3D _ (mirrorPt1, mirrorPt2, mirrorPt3) mirrorBoxObj.Color = acRed ZoomAll End Sub |
GMT+8, 2024-6-10 23:24
