若要创建几何公差,请使用该方法。AddTolerance 此方法需要三个值作为输入:包含公差符号的文本字符串、图形中放置公差的位置以及指定公差方向的方向矢量。您还可以复制、移动、擦除、缩放和旋转容差。 创建几何公差本示例在模型空间中创建一个简单的几何公差。 Sub Ch5_CreateTolerance() Dim toleranceObj As AcadTolerance Dim textString As String Dim insertionPoint(0 To 2) As Double Dim direction(0 To 2) As Double ' Define the tolerance object textString = "Here is the Feature Control Frame" insertionPoint(0) = 5 insertionPoint(1) = 5 insertionPoint(2) = 0 direction(0) = 1 direction(1) = 1 direction(2) = 0 ' Create the tolerance object in model space Set toleranceObj = ThisDrawing.ModelSpace. _ AddTolerance(textString, insertionPoint, direction) ZoomAll End Sub |
GMT+8, 2024-6-11 03:18
