有九个与选项相关的对象,每个对象表示“选项”对话框中的一个选项卡。 这些对象提供对“选项”对话框中所有注册表存储选项的访问。您可以使用在这些对象上找到的特性来自定义许多 AutoCAD 设置。这些对象是
这些对象可通过该对象访问。要获得对对象的访问权限,请使用对象的属性:PreferencesPreferencesPreferencesApplication Dim acadPref as AcadPreferences Set acadPref = ThisDrawing.Application.Preferences 然后,您可以使用 ,,,,,,,, 和属性访问任何特定对象。PreferencesDisplayDraftingFilesOpenSaveOutputProfileSelectionSystemUser 将十字准线设置为全屏Sub Ch2_PrefsSetCursor() ' This example sets the crosshairs of the AutoCAD drawing cursor ' to full screen. ' Access the Preferences object Dim acadPref As AcadPreferences Set acadPref = ThisDrawing.Application.Preferences ' Use the CursorSize property to set the size of the crosshairs acadPref.Display.CursorSize = 100 End Sub 显示屏幕菜单和滚动条Sub Ch2_PrefsSetDisplay() ' This example disables the scroll ' bars with the DisplayScrollBars ' properties. ' Access the Preferences object Dim acadPref As AcadPreferences Set acadPref = ThisDrawing.Application.Preferences ' Display the and disable scroll bars acadPref.Display.DisplayScrollBars = False End Sub |
GMT+8, 2024-6-10 17:53
