在基于 AutoCAD 2010 和基于 AutoCAD 2010 的产品中对 ActiveX API 所做的添加和更改。 枚举AcEntityName (Changed) acSubDMesh = 49 (New) acPdfUnderlay = 50 (New) AcPlotScale (Changed) ac1_8 = 19 (Removed) ac1_10 = 20 (Removed) ac1_16 = 21 (Removed) ac1_20 = 22 (Removed) ac1_30 = 23 (Removed) ac1_40 = 24 (Removed) ac1_50 = 25 (Removed) ac1_100 = 26 (Removed) ac2_1 = 27 (Removed) ac4_1 = 28 (Removed) ac8_1 = 29 (Removed) ac10_1 = 30 (Removed) ac100_1 = 31 (Removed) ac1_5 = 19 (New) ac1_8 = 20 (New) ac1_10 = 21 (New) ac1_16 = 22 (New) ac1_20 = 23 (New) ac1_30 = 24 (New) ac1_40 = 25 (New) ac1_50 = 26 (New) ac1_100 = 27 (New) ac2_1 = 28 (New) ac4_1 = 29 (New) ac8_1 = 30 (New) ac10_1 = 31 (New) ac100_1 = 32 (New) AcDimVerticalJustification (Changed) acUnder = 4 (New) AcViewportScale (Changed) acVp1 = 2 (Removed) acVp2 = 3 (Removed) acVp3 = 4 (Removed) acVp4 = 5 (Removed) acVp5 = 6 (Removed) acVp6 = 7 (Removed) acVp7 = 8 (Removed) acVp8 = 9 (Removed) acVp9 = 10 (Removed) acVp10 = 11 (Removed) acVp11 = 12 (Removed) acVp12 = 13 (Removed) acVp13 = 14 (Removed) acVp14 = 15 (Removed) acVp15 = 16 (Removed) acVp16 = 17 (Removed) acVp17 = 18 (Removed) acVp18 = 19 (Removed) acVp19 = 20 (Removed) acVp20 = 21 (Removed) acVp21 = 22 (Removed) acVp22 = 23 (Removed) acVp23 = 24 (Removed) acVp24 = 25 (Removed) acVp25 = 26 (Removed) acVp26 = 27 (Removed) acVp27 = 28 (Removed) acVp28 = 29 (Removed) acVp29 = 30 (Removed) acVp30 = 31 (Removed) acVp31 = 32 (Removed) acVp32 = 33 (Removed) acVp33 = 34 (Removed) acVp34 = 35 (Removed) acVp35 = 36 (Removed) acVp36 = 37 (Removed) acVp37 = 38 (Removed) acVp38 = 39 (Removed) acVp39 = 40 (Removed) acVp40 = 41 (Removed) acVp41 = 42 (Removed) acVp42 = 43 (Removed) acVp43 = 44 (Removed) acVp44 = 45 (Removed) acVp45 = 46 (Removed) acVp46 = 47 (Removed) acVp47 = 48 (Removed) acVp48 = 49 (Removed) acVp49 = 50 (Removed) acVp50 = 51 (Removed) acVp51 = 52 (Removed) acVp52 = 53 (Removed) acVp53 = 54 (Removed) acVp54 = 55 (Removed) acVp55 = 56 (Removed) acVp56 = 57 (Removed) acVp57 = 58 (Removed) acVp58 = 59 (Removed) acVp59 = 60 (Removed) acVp60 = 61 (Removed) acVp61 = 62 (Removed) acVp62 = 63 (Removed) acVp63 = 64 (Removed) acVp64 = 65 (Removed) acVp65 = 66 (Removed) acVp66 = 67 (Removed) acVp67 = 68 (Removed) acVp68 = 69 (Removed) acVp69 = 70 (Removed) acVp70 = 71 (Removed) acVp71 = 72 (Removed) acVp72 = 73 (Removed) acVp73 = 74 (Removed) acVp74 = 75 (Removed) acVp75 = 76 (Removed) acVp76 = 77 (Removed) acVp77 = 78 (Removed) acVp78 = 79 (Removed) acVp79 = 80 (Removed) acVp80 = 81 (Removed) acVp81 = 82 (Removed) acVp82 = 83 (Removed) acVp83 = 84 (Removed) acVp84 = 85 (Removed) acVp85 = 86 (Removed) acVp86 = 87 (Removed) acVp87 = 88 (Removed) acVp88 = 89 (Removed) acVp89 = 90 (Removed) acVp90 = 91 (Removed) acVp91 = 92 (Removed) acVp92 = 93 (Removed) acVp93 = 94 (Removed) acVp94 = 95 (Removed) acVp95 = 96 (Removed) acVp96 = 97 (Removed) acVp97 = 98 (Removed) acVp98 = 99 (Removed) acVp99 = 100 (Removed) acVp100 = 101 (Removed) acVp1_8 = 5 (Removed) acVp1_10 = 6 (Removed) acVp1_16 = 7 (Removed) acVp1_20 = 8 (Removed) acVp1_30 = 9 (Removed) acVp1_40 = 10 (Removed) acVp1_50 = 11 (Removed) acVp1_100 = 12 (Removed) acVp2_1 = 13 (Removed) acVp4_1 = 14 (Removed) acVp8_1 = 15 (Removed) acVp10_1 = 16 (Removed) acVp100_1 = 17 (Removed) acVp1_128in_1ft = 18 (Removed) acVp1_64in_1ft = 19 (Removed) acVp1_32in_1ft = 20 (Removed) acVp1_16in_1ft = 21 (Removed) acVp3_32in_1ft = 22 (Removed) acVp1_8in_1ft = 23 (Removed) acVp3_16in_1ft = 24 (Removed) acVp1_4in_1ft = 25 (Removed) acVp3_8in_1ft = 26 (Removed) acVp1_2in_1ft = 27 (Removed) acVp3_4in_1ft = 28 (Removed) acVp1in_1ft = 29 (Removed) acVp1and1_2in_1ft = 30 (Removed) acVp3in_1ft = 31 (Removed) acVp6in_1ft = 32 (Removed) acVp1ft_1ft = 33 (Removed) acVp1_5 = 5 (New) acVp1_8 = 6 (New) acVp1_10 = 7 (New) acVp1_16 = 8 (New) acVp1_20 = 9 (New) acVp1_30 = 10 (New) acVp1_40 = 11 (New) acVp1_50 = 12 (New) acVp1_100 = 13 (New) acVp2_1 = 14 (New) acVp4_1 = 15 (New) acVp8_1 = 16 (New) acVp10_1 = 17 (New) acVp100_1 = 18 (New) acVp1_128in_1ft = 19 (New) acVp1_64in_1ft = 20 (New) acVp1_32in_1ft = 21 (New) acVp1_16in_1ft = 22 (New) acVp3_32in_1ft = 23 (New) acVp1_8in_1ft = 24 (New) acVp3_16in_1ft = 25 (New) acVp1_4in_1ft = 26 (New) acVp3_8in_1ft = 27 (New) acVp1_2in_1ft = 28 (New) acVp3_4in_1ft = 29 (New) acVp1in_1ft = 30 (New) acVp1and1_2in_1ft = 31 (New) acVp3in_1ft = 32 (New) acVp6in_1ft = 33 (New) acVp1ft_1ft = 34 (New) AcTextAttachmentDirection (New) acAttachmentHorizontal = 0 acAttachmentVertical = 1 AcVerticalTextAttachmentType (New) acAttachmentCenter = 0 acAttachmentLinedCenter = 1 AcMeshCreaseType (New) acNoneCrease = 0 acAlwaysCrease = 1 acCreaseByLevel = 2 ClassesIAcadBlock (Changed) AddMLeader - Method (Moved from IAcadBlock2) IAcadAttribute (Changed) MTextAttribute - Property (Moved from IAcadAttribute2) MTextAttributeContent - Property (Moved from IAcadAttribute2) UpdateMTextAttribute - Method (Moved from IAcadAttribute2) MTextBoundaryWidth - Property (Moved from IAcadAttribute2) MTextDrawingDirection - Property (Moved from IAcadAttribute2) IAcadDimAligned (Changed) DimConstrForm - Property (New) DimConstrReference - Property (New) DimConstrName - Property (New) DimConstrExpression - Property (New) DimConstrValue - Property (New) DimConstrDesc - Property (New) SubUnitsSuffix - Property (New) SubUnitsFactor - Property (New) AltSubUnitsSuffix - Property (New) AltSubUnitsFactor - Property (New) IAcadDimension (Changed) DimTxtDirection - Property (New) IAcadDimAngular (Changed) DimConstrForm - Property (New) DimConstrReference - Property (New) DimConstrName - Property (New) DimConstrExpression - Property (New) DimConstrValue - Property (New) DimConstrDesc - Property (New) IAcadDimDiametric (Changed) DimConstrForm - Property (New) DimConstrReference - Property (New) DimConstrName - Property (New) DimConstrExpression - Property (New) DimConstrValue - Property (New) DimConstrDesc - Property (New) IAcadDimRotated (Changed) DimConstrForm - Property (New) DimConstrReference - Property (New) DimConstrName - Property (New) DimConstrExpression - Property (New) DimConstrValue - Property (New) DimConstrDesc - Property (New) SubUnitsSuffix - Property (New) SubUnitsFactor - Property (New) AltSubUnitsSuffix - Property (New) AltSubUnitsFactor - Property (New) IAcadDimOrdinate (Changed) SubUnitsSuffix - Property (New) SubUnitsFactor - Property (New) AltSubUnitsSuffix - Property (New) AltSubUnitsFactor - Property (New) IAcadDimRadial (Changed) DimConstrForm - Property (New) DimConstrReference - Property (New) DimConstrName - Property (New) DimConstrExpression - Property (New) DimConstrValue - Property (New) DimConstrDesc - Property (New) IAcadDim3PointAngular (Changed) DimConstrForm - Property (New) DimConstrReference - Property (New) DimConstrName - Property (New) DimConstrExpression - Property (New) DimConstrValue - Property (New) DimConstrDesc - Property (New) IAcadTable (Changed) IsEmpty - Method (Moved from IAcadTable2) CreateContent - Method (Moved from IAcadTable2) MoveContent - Method (Moved from IAcadTable2) DeleteContent - Method (Moved from IAcadTable2) GetValue - Method (Moved from IAcadTable2) SetValue - Method (Moved from IAcadTable2) SetValueFromText - Method (Moved from IAcadTable2) GetDataFormat - Method (Moved from IAcadTable2) SetDataFormat - Method (Moved from IAcadTable2) GetTextString - Method (Moved from IAcadTable2) SetTextString - Method (Moved from IAcadTable2) GetFieldId2 - Method (Moved from IAcadTable2) SetFieldId2 - Method (Moved from IAcadTable2) GetBlockTableRecordId2 - Method (Moved from IAcadTable2) SetBlockTableRecordId2 - Method (Moved from IAcadTable2) GetBlockAttributeValue2 - Method (Moved from IAcadTable2) SetBlockAttributeValue2 - Method (Moved from IAcadTable2) GetCustomData - Method (Moved from IAcadTable2) SetCustomData - Method (Moved from IAcadTable2) GetCellStyle - Method (Moved from IAcadTable2) SetCellStyle - Method (Moved from IAcadTable2) GetContentColor2 - Method (Moved from IAcadTable2) SetContentColor2 - Method (Moved from IAcadTable2) GetDataType2 - Method (Moved from IAcadTable2) SetDataType2 - Method (Moved from IAcadTable2) GetTextStyle2 - Method (Moved from IAcadTable2) SetTextStyle2 - Method (Moved from IAcadTable2) GetTextHeight2 - Method (Moved from IAcadTable2) SetTextHeight2 - Method (Moved from IAcadTable2) GetRotation - Method (Moved from IAcadTable2) SetRotation - Method (Moved from IAcadTable2) GetAutoScale2 - Method (Moved from IAcadTable2) SetAutoScale2 - Method (Moved from IAcadTable2) GetScale - Method (Moved from IAcadTable2) SetScale - Method (Moved from IAcadTable2) RemoveAllOverrides - Method (Moved from IAcadTable2) GetGridLineWeight2 - Method (Moved from IAcadTable2) SetGridLineWeight2 - Method (Moved from IAcadTable2) GetGridLinetype - Method (Moved from IAcadTable2) SetGridLinetype - Method (Moved from IAcadTable2) GetGridColor2 - Method (Moved from IAcadTable2) SetGridColor2 - Method (Moved from IAcadTable2) GetGridVisibility2 - Method (Moved from IAcadTable2) SetGridVisibility2 - Method (Moved from IAcadTable2) GetGridDoubleLineSpacing - Method (Moved from IAcadTable2) SetGridDoubleLineSpacing - Method (Moved from IAcadTable2) EnableBreak - Property (Moved from IAcadTable2) GetBreakHeight - Method (Moved from IAcadTable2) SetBreakHeight - Method (Moved from IAcadTable2) GetContentType - Method (Moved from IAcadTable2) GetMargin - Method (Moved from IAcadTable2) SetMargin - Method (Moved from IAcadTable2) GetContentLayout - Method (Moved from IAcadTable2) SetContentLayout - Method (Moved from IAcadTable2) GetOverride - Method (Moved from IAcadTable2) SetOverride - Method (Moved from IAcadTable2) GetGridLineStyle - Method (Moved from IAcadTable2) SetGridLineStyle - Method (Moved from IAcadTable2) InsertRowsAndInherit - Method (Moved from IAcadTable2) InsertColumnsAndInherit - Method (Moved from IAcadTable2) GetHasFormula - Method (Moved from IAcadTable2) GetFormula - Method (Moved from IAcadTable2) SetFormula - Method (Moved from IAcadTable2) IsContentEditable - Method (Moved from IAcadTable2) IsFormatEditable - Method (Moved from IAcadTable2) GetCellState - Method (Moved from IAcadTable2) SetCellState - Method (Moved from IAcadTable2) EnableMergeAll - Method (Moved from IAcadTable2) IsMergeAllEnabled - Method (Moved from IAcadTable2) BreaksEnabled - Property (Moved from IAcadTable2) RepeatTopLabels - Property (Moved from IAcadTable2) RepeatBottomLabels - Property (Moved from IAcadTable2) TableBreakFlowDirection - Property (Moved from IAcadTable2) AllowManualPositions - Property (Moved from IAcadTable2) AllowManualHeights - Property (Moved from IAcadTable2) TableBreakHeight - Property (Moved from IAcadTable2) BreakSpacing - Property (Moved from IAcadTable2) GetColumnName - Method (Moved from IAcadTable2) SetColumnName - Method (Moved from IAcadTable2) SetToolTip - Method (Moved from IAcadTable2) GetFieldId232 - Method (Moved from IAcadTable2) SetFieldId232 - Method (Moved from IAcadTable2) GetBlockTableRecordId232 - Method (Moved from IAcadTable2) SetBlockTableRecordId232 - Method (Moved from IAcadTable2) GetBlockAttributeValue232 - Method (Moved from IAcadTable2) SetBlockAttributeValue232 - Method (Moved from IAcadTable2) GetGridLinetype32 - Method (Moved from IAcadTable2) SetGridLinetype32 - Method (Moved from IAcadTable2) IAcadDimArcLength (Changed) SubUnitsSuffix - Property (New) SubUnitsFactor - Property (New) AltSubUnitsSuffix - Property (New) AltSubUnitsFactor - Property (New) IAcadMLeader (Changed) LeaderLinetype - Property (Renamed, previously LeaderLineType) BlockScale - Property (New) TextAttachmentDirection - Property (New) TextTopAttachmentType - Property (New) TextBottomAttachmentType - Property (New) IAcadPViewport (Changed) StandardScale2 - Property (New) LayerPropertyOverrides - Property (Moved from IAcadPViewport2) IAcadTableStyle (Changed) CreateCellStyle - Method (Moved from IAcadTableStyle2) CreateCellStyleFromStyle - Method (Moved from IAcadTableStyle2) RenameCellStyle - Method (Moved from IAcadTableStyle2) DeleteCellStyle - Method (Moved from IAcadTableStyle2) GetUniqueCellStyleName - Method (Moved from IAcadTableStyle2) GetIsCellStyleInUse - Method (Moved from IAcadTableStyle2) NumCellStyles - Property (Moved from IAcadTableStyle2) GetCellStyles - Method (Moved from IAcadTableStyle2) GetTextStyleId - Method (Moved from IAcadTableStyle2) SetTextStyleId - Method (Moved from IAcadTableStyle2) GetTextHeight2 - Method (Moved from IAcadTableStyle2) SetTextHeight2 - Method (Moved from IAcadTableStyle2) GetAlignment2 - Method (Moved from IAcadTableStyle2) SetAlignment2 - Method (Moved from IAcadTableStyle2) GetColor2 - Method (Moved from IAcadTableStyle2) SetColor2 - Method (Moved from IAcadTableStyle2) GetBackgroundColor2 - Method (Moved from IAcadTableStyle2) SetBackgroundColor2 - Method (Moved from IAcadTableStyle2) GetDataType2 - Method (Moved from IAcadTableStyle2) SetDataType2 - Method (Moved from IAcadTableStyle2) GetFormat2 - Method (Moved from IAcadTableStyle2) SetFormat2 - Method (Moved from IAcadTableStyle2) GetCellClass - Method (Moved from IAcadTableStyle2) SetCellClass - Method (Moved from IAcadTableStyle2) GetRotation - Method (Moved from IAcadTableStyle2) SetRotation - Method (Moved from IAcadTableStyle2) GetIsMergeAllEnabled - Method (Moved from IAcadTableStyle2) EnableMergeAll - Method (Moved from IAcadTableStyle2) GetGridLineWeight2 - Method (Moved from IAcadTableStyle2) SetGridLineWeight2 - Method (Moved from IAcadTableStyle2) GetGridColor2 - Method (Moved from IAcadTableStyle2) SetGridColor2 - Method (Moved from IAcadTableStyle2) GetGridVisibility2 - Method (Moved from IAcadTableStyle2) SetGridVisibility2 - Method (Moved from IAcadTableStyle2) TemplateId - Property (Moved from IAcadTableStyle2) SetTemplateId - Method (Moved from IAcadTableStyle2) GetTextStyleId32 - Method (Moved from IAcadTableStyle2) SetTextStyleId32 - Method (Moved from IAcadTableStyle2) TemplateId32 - Property (Moved from IAcadTableStyle2) SetTemplateId32 - Method (Moved from IAcadTableStyle2) IAcadMLeaderStyle (Changed) LeaderLinetype - Property (Renamed, previously LeaderLineType) TextAttachmentDirection - Property (New) TextTopAttachmentType - Property (New) TextBottomAttachmentType - Property (New) IAcadAttributeReference (Changed) MTextAttribute - Property (Moved from IAcadAttributeReference2) MTextAttributeContent - Property (Moved from IAcadAttributeReference2) UpdateMTextAttribute - Method (Moved from IAcadAttributeReference2) MTextBoundaryWidth - Property (Moved from IAcadAttributeReference2) MTextDrawingDirection - Property (Moved from IAcadAttributeReference2) IAcadMLeaderLeader (New) LeaderType - Property LeaderLineColor - Property LeaderLinetype - Property LeaderLineWeight - Property ArrowheadType - Property ArrowheadSize - Property ArrowheadBlock - Property IAcadUnderlay (Changed) UnderlayLayerOverrideApplied - Property (Moved from IAcadUnderlay2) IAcadDwfUnderlay (New) DWFFormat - Property (Moved from IAcadUnderlay3) IAcadSubDMesh (New) Smoothness - Property Coordinates - Property Coordinate - Property VertexCount - Property FaceCount - Property IAcadSubDMeshFace (New) Material - Property CreaseType - Property CreaseLevel - Property IAcadSubDMeshEdge (New) CreaseType - Property CreaseLevel - Property IAcadSubDMeshVertex (New) Coordinates - Property CreaseType - Property CreaseLevel - Property IAcadModelSpace (Changed) AddMLeader - Method (Moved from IAcadModelSpace2) IAcadPaperSpace (Changed) AddMLeader - Method (Moved from IAcadPaperSpace2) IAcadPreferencesUser (Changed) HyperlinkDisplayTooltip - Property (Removed) IAcadToolbarItem (Changed) CommandDisplayName - Property (Moved from IAcadToolbarItem2) IAcadUtility (Changed) GetSubEntity32 - Method (Moved from IAcadUtility2) ObjectId32ToObjectIdString - Method (Moved from IAcadUtility2) GetObjectIdString - Method (Moved from IAcadUtility2) 以下类已与其父类删除/合并: IAcadTableStyle2 (Removed - Moved to IAcadTableStyle) IAcadAttribute2 (Removed - Moved to IAcadAttribute) IAcadAttributeReference2 (Removed - Moved to IAcadAttributeReference) IAcadPViewport2 (Removed - Moved to IAcadPViewport) IAcadTable2 (Removed - Moved to IAcadTable) IAcadUnderlay2 (Removed - Moved to IAcadUnderlay) IAcadUnderlay3 (Removed - Moved to IAcadUnderlay) IAcadBlock2 (Removed - Moved to IAcadBlock) IAcadModelSpace2 (Removed - Moved to IAcadModelSpace) IAcadPaperSpace2 (Removed - Moved to IAcadPaperSpace) IAcadUtility2 (Removed - Moved to IAcadUtility) IAcadToolbarItem2 (Removed - Moved to IAcadToolbarItem) |
( 苏ICP备2022047690号-1 )
GMT+8, 2024-6-11 05:11
