在基于 AutoCAD 2017 和基于 AutoCAD 2017 的产品中对 ActiveX API 所做的添加和更改。 枚举AcInsertUnits (Changed) acInsertUnitsUSSurveyFeet = 21 (New) acInsertUnitsUSSurveyInch = 22 (New) acInsertUnitsUSSurveyYard = 23 (New) acInsertUnitsUSSurveyMile = 24 (New) 类AcadAcCmColor Version number of the class has been incremented from 20 to 21; use the ProgID AutoCAD.AcCmColor.21. AcadApplication Version number of the class has been incremented from 20 to 21; use the ProgID AutoCAD.Application.21. ProgID AutoCAD.Application.20.1 is now obsolete. AcadLayerStateManager Version number of the class has been incremented from 20 to 21; use the ProgID AutoCAD.AcadLayerStateManager.21. AcadSecurityParams Version number of the class has been incremented from 20 to 21; use the ProgID AutoCAD.SecurityParams.21. IAcadShadowDisplay (Obsolete) EnableShadowDisplay - Property (Obsolete) ShadowDisplay - Property (Obsolete) |
( 苏ICP备2022047690号-1 )
GMT+8, 2024-6-11 00:08
