在基于AutoCAD 2020 和基于 AutoCAD 2020 的产品中对 ActiveX API 所做的添加和更改。 类AcadApplication Minor version number of the class has been incremented from 23.0 to 23.1 Use the ProgID AutoCAD.Application.23.1 to create an instance of AutoCAD 2020 or ProgID AutoCAD.Application.23.0 to create an instance of AutoCAD 2019, when installed. ProgID AutoCAD.Application.23 can still be used to create an instance of AutoCAD 2020, but there will be inconsistencies in execution when installed side-by-side with AutoCAD 2019. IAcadComparedReference (New) Inherits from IAcadExternalReference
GMT+8, 2024-6-2 17:34
