0
无错误
1
符号表名称无效
2
无效的实体或选择集名称
3
超出最大选择集数
4
无效的选择集
5
块定义的使用不当
6
外部参照使用不当
7
对象选择:拾取失败
8
实体文件结束
9
块定义文件结束
10
找不到最后一个实体
11
非法尝试删除视口对象
12
PLINE期间不允许操作
13
无效的句柄
14
句柄未启用
15
坐标转换请求中的参数无效
16
坐标转换请求中的空格无效
17
无效使用已删除的实体
18
表名无效
19
无效的表函数参数
20
尝试设置只读变量
21
Zero value not allowed
22
Value out of range
23
Complex REGEN in progress
24
Attempt to change entity type
25
Bad layer name
26
Bad linetype name
27
Bad color name
28
Bad text style name
29
Bad shape name
30
Bad field for entity type
31
Attempt to modify deleted entity
32
Attempt to modify seqend subentity
33
Attempt to change handle
34
Attempt to modify viewport visibility
35
Entity on locked layer
36
Bad entity type
37
Bad polyline entity
38
Incomplete complex entity in block
39
Invalid block name field
40
Duplicate block flag fields
41
Duplicate block name fields
42
Bad normal vector
43
Missing block name
44
Missing block flags
45
Invalid anonymous block
46
Invalid block definition
47
Mandatory field missing
48
Unrecognized extended data (XDATA) type
49
Improper nesting of list in XDATA
50
Improper location of APPID field
51
Exceeded maximum XDATA size
52
Entity selection: null response
53
Duplicate APPID
54
Attempt to make or modify viewport entity
55
Attempt to make or modify an xref, xdef, or xdep
56
ssget filter: unexpected end of list
57
ssget filter: missing test operand
58
ssget filter: invalid opcode (-4) string
59
ssget filter: improper nesting or empty conditional clause
60
ssget filter: mismatched begin and end of conditional clause
61
ssget filter: wrong number of arguments in conditional clause (for NOT or XOR)
62
ssget filter: exceeded maximum nesting limit
63
ssget filter: invalid group code
64
ssget filter: invalid string test
65
ssget filter: invalid vector test
66
ssget filter: invalid real test
67
ssget filter: invalid integer test
68
Digitizer is not a tablet
69
Tablet is not calibrated
70
Invalid tablet arguments
71
ADS error: Unable to allocate new result buffer
72
ADS error: Null pointer detected
73
Cannot open executable file
74
Application is already loaded
75
已加载的最大应用程序数
76
无法执行应用程序
77
不兼容的版本号
78
无法卸载嵌套的应用程序
79
应用程序被拒绝卸载
80
应用程序当前未加载
81
内存不足,无法加载应用程序
82
ADS 错误:转换矩阵无效
83
ADS 错误:符号名称无效
84
ADS 错误:符号值无效
85
显示对话框时禁止 AutoLISP/ADS 操作
