返回要在 VLA 方法中使用的 4 x 4 转换矩阵的合适表示形式 支持的平台:仅窗口 签名(vlax-tmatrix lst)
返回值类型:变体 安全数组类型的变体,表示 4×4 转换矩阵。 例子定义转换矩阵并将其值分配给变量:tmatrix (setq tmatrix (vlax-tmatrix '((1 1 1 0) (1 2 3 0) (2 3 4 5) (2 9 8 3)))) #<variant 8197 ...> 用于查看列表表单中的值:vlax-safearray->listtmatrix (vlax-safearray->list (vlax-variant-value tmatrix)) ((1.0 1.0 1.0 0.0) (1.0 2.0 3.0 0.0) (2.0 3.0 4.0 5.0) (2.0 9.0 8.0 3.0)) 下面的代码示例创建一条线,并使用转换矩阵将其旋转 90 度: (defun Example_TransformBy ( / acadObject acadDocument mSpace lineObj startPt endPt matList transMat) (vl-load-com) ; Load ActiveX support (setq acadObject (vlax-get-acad-object)) (setq acadDocument (vla-get-ActiveDocument acadObject)) (setq mSpace (vla-get-ModelSpace acadDocument)) ;;; Create a line (setq startPt (getpoint "\nPick the start point: ")) (setq endPt (vlax-3d-point (getpoint startPt "\nPick the end point: "))) (setq lineObj (vla-addline mSpace (vlax-3d-point startPt) endPt)) ;;; Initialize the transMat variable with a transformation matrix ;;; that will rotate an object by 90 degrees about the point(0,0,0). ;;; Begin by Creating a list of four lists, each containing four ;;; numbers, representing transformation matrix elements. (setq matList (list '(0 -1 0 0) '(1 0 0 0) '(0 0 1 0) '(0 0 0 1))) ;;; Use vlax-tmatrix to convert the list to a variant. (setq transmat (vlax-tmatrix matlist)) ;;; Transform the line using the defined transformation matrix (vla-transformby lineObj transMat) (vla-zoomall acadObject) (prompt "\nThe line has been transformed.") (princ) ) |
GMT+8, 2024-6-2 20:50
