下面的示例绘制一个以原点为中心的单位圆。绘制的确切圆取决于视口对圆的视图。目标是用具有最少可识别段数的折线绘制一个圆。使用 VPORTS 命令,您可以创建四个视口,然后单击一个并放大圆圈,然后单击另一个并从中备份。执行 REGENALL 时,每个视口都会计算其自己的最小分段的圆折线表示。 这就是该示例计算折线中必要线段数的方式。首先,给定一个以原点为中心且位于XY平面中的给定半径的圆,并给定一条以半径 - 0.5 像素与 X 轴相交的垂直线,确定X轴与从原点延伸到垂直线与圆相交的点的线段之间的角度。两个 pi 除以此角度提供了折线看起来像圆所需的最小段数。用户将无法区分构成圆的各个线段,因为视觉差异小于一个像素。 Adesk::Boolean AsdkTesselateSamp::subWorldDraw(AcGiWorldDraw *pW) { // Draw a red 1 x 1 drawing-unit square centered at the // world coordinate origin and parallel to the XY-plane. // const Adesk::UInt32 num_pts = 5; AcGePoint3d verts[num_pts]; verts[0] = verts[4] = AcGePoint3d(-0.5, -0.5, 0.0); verts[1] = AcGePoint3d( 0.5, -0.5, 0.0); verts[2] = AcGePoint3d( 0.5, 0.5, 0.0); verts[3] = AcGePoint3d(-0.5, 0.5, 0.0); pW- >subEntityTraits().setColor(kRed); pW->geometry ().polyline(num_pts, verts); // If regenType is kAcGiSaveWorldDrawForProxy then we // must return Adesk::kTrue, otherwise we need to return // Adesk::kFalse to trigger calls to our viewportDraw(). // return (pW- >regenType() == kAcGiSaveWorldDrawForProxy); } void AsdkTesselateSamp::subViewportDraw(AcGiViewportDraw *pV) { static double two_pi = atan(1.0) * 8.0; // Get the number of pixels on the X- and Y-edges of // a unit square centered at (0.0, 0.0, 0.0), in // world coordinates. // AcGePoint3d center(0.0, 0.0, 0.0); AcGePoint2d area; pV->viewport ().getNumPixelsInUnitSquare(center, area); // If the 'area' values are negative, then we are in // perspective mode and the 'center' is too close or // in back of the viewport. // if (area.x > 0.0) { // Print out the number of pixels along the // y-axis of the unit square used in // getNumPixelsInUnitSquare. // AcGeVector3d norm(0.0, 0.0, 1.0); AcGeVector3d dir(1.0, 0.0, 0.0); TCHAR buf[100]; _stprintf(buf, _T("%7.3lf"), area.y); pV->geometry ().text(center, norm, dir, 1.0, 1.0, 0.0, buf); // Draw a circle that depends on how big the circle // is in the viewport. This is a problem of // figuring out the least number of segments needed // by a polyline so it doesn't look segmented. // // By the way, the worldDraw() and viewportDraw() of // an entity in a viewport are only called during a // regen and not necessarily during a ZOOM or PAN. // The reason is that a REGEN produces something // akin to a very high resolution image internally // that AutoCAD can zoom in or pan around, // until you get too close to this image or any of // its edges -- at which point a REGEN is internally // invoked for that viewport and a new internal // image is created (ready to be mildly zoomed and // panned upon.) // double radius = 0.5; double half_pixel_hgt = 2.0 / area.x; // in world // coords int num_segs = 8; double angle = two_pi / num_segs; if (half_pixel_hgt > radius / 2) { // The circle is around or less than the size // of a pixel. So generate a very small octagon. num_segs = 8; } else { // Given a circle centered at the origin of a // given 'radius' in the XY-plane, and given a // vertical line that intersects the X-axis at // 'radius - half a pixel', what is the angle // from the X- axis of a line segment from the // origin to the point where the vertical line // and the circle intersect? Two pi divided by // this angle gives you a minimum number of // segments needed by a polyline to 'look' like // a circle and not be able to differentiate // the individual segments because the visual // differences are less than the size of a // pixel. (This is not the only way to figure // this out but it's sufficient.) // angle = acos ((radius - 1.0 / (area.x / 2.0)) / radius); double d_num_segs = two_pi / angle; // Limit the number of segments from 8 to // 128 and use whole numbers for // this count. // if (d_num_segs < 8.0) { num_segs = 8; } else if (d_num_segs > 128.0) { num_segs = 128; } else { num_segs = (int)d_num_segs; } } // Calculate the vertices of the polyline from the // start, around the circle, and back to the start // to close the polyline. // angle = 0.0; double angle_inc = two_pi / (double)num_segs; AcGePoint3d* verts = new AcGePoint3d[num_segs + 1]; for (int i = 0; i <= num_segs; i++, angle += angle_inc) { verts[i].x = center.x + radius * cos(angle); verts[i].y = center.y + radius * sin(angle); verts[i].z = center.z; } pV->geometry ().polyline(num_segs + 1, verts); delete [] verts; } } |
GMT+8, 2024-6-2 20:47
